| Hi Rob, Sorry to hear you're having problems. ![]() Have a look at the link in my signature and you'll find my guide to power steering pumps. There are some links in the guide to posts by some of MINI2's technical gurus who made a DIY procedure for cleaning out the pump, which might help in this case. Good luck! ![]() All the best, Andrew. NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE). Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix] |
| Ah, you're got the signature's on posts set to off then. Here's the direct link: http://www.mini2.com/forum/first-gen...ml#post3686894 Happy reading. ![]() All the best, Andrew. NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE). Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix] |
| Fuse = FL4 100A Electric Steering control unit/Hydraulic pump Link:- http://www.mini2.com/forum/general-d...th-points.html Disconnect battery or pull 100A fuse above, otherwise PS pump running constantly flat out can overheat PS fluid and cause damage to the steering rack oil seals, or in worst case catch fire!! Should be ok to drive a short journey to garage but pull fuse while parked up. How to DIY replace pump:- Power Steering Pump replacement - Forums |
| Youve got the same problem as i had mate, just got mine fixed on wednesday new pump and labor came to £310! but glad its all done and sorted now and im glad i never went with Mini who wanted £650 and that was just for the pump ![]() let me know how you get on Steven |
| Tags: battery, buzzing, power, pump, steering |
| Fan stays on for 5 mins after ignition off | Vandalay Industries | First Generation Faults & Fixes | 10 | May 11th, 2009 04:59 PM |
| Kenwood 6541U power on without ignition? | FishFan | First Generation Interior & Ice | 0 | Apr 6th, 2009 03:34 PM |
| Power Steering goes out, high speed fan and power steering fan aren't staying on. | Niko | First Generation Faults & Fixes | 3 | Jul 7th, 2008 02:25 PM |
| power steering pump cooling fan stays on... Why? | 1rabbit | First Generation Faults & Fixes | 7 | Nov 16th, 2006 05:53 PM |
| Ignition Power Tap - HELP | RAP | First Generation Interior & Ice | 6 | Apr 24th, 2005 05:58 PM |
