Tailgate Problems (again...) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 28th, 2002, 02:38 PM
Local Time: 04:18 AM
(apologies in advance for another tailgate post, but...)
Could I reject my Mini based on a faulty tailgate?
Last night (in the pouring rain) I tried for 30 mins to close the tailgate - eventually it "closed", but the tailgate warning light stayed on (found it hard to convince myself this is a new car!!!)
I've been to my dealer 5 times regarding the above (plus rattles) - they have tried everything - new mech, lock adjustments, bit of plastic to stop rattles, etc., but every time it just slowly gets worse. I now find myself reluctant to open the damn thing, fearing I may not be able to close it.
I know it seems kind of ridiculous to reject a car based on the above, but what can I do? I consider this a security risk.
Old Oct 28th, 2002, 02:53 PM
Clutch Cargo's Avatar
United States View Clutch Cargo's British Racing Green & White 1st Gen MINI Cooper Profile
Radish, it sounds like your dealer doesn't have a competent mechanic on staff. Dumb question I know, but have you tried going to a different dealership for this repair? This problem should be fixable, it seems to me.
Good luck, anyway.
BRG/W MC 15" white seven-holes, DSC, Sport seats -- Motoring since Oct 7 of 2002
Old Oct 29th, 2002, 10:57 AM
stanMINI's Avatar
Local Time: 10:18 PM
I don't know if this is your problem or not, but I had a similar experience with the tailgate not latching.
It turns out that the because the latch is electronic and not mechanical, to some extent anyway, that if it is toggled open it won't latch. You may just need to pull the handle one click to get the thing to latch again. I have kids that open the boot and let the thing click multiple times and that is when I can get into trouble. Now that I know what the problem is, it is easy to fix.
Cooper S - Chili Red w/Black
The road goes on forever and the party never ends.
Old Oct 29th, 2002, 06:29 PM
INFO ONLY:-
How to re-initialise the tailgate mechanism..
1)With the tailgate open,allow 1 minute to pass,then lock and unlock the car (via the remote key),then press the release button on the tailgate.You should hear the latch reset itself,the boot should now close okay...
2)If this does not work,leave the tailgate open,manually close the catch (using a screwdriver which should hopefully reset the microswitch in the latch itself)then press the release button on the tailgate,again you should hear the catch reset itself..
3)if all this fails call the dealer..you need a new catch..!
If you are stuck and need to get INTO the boot but are unable to,sit in the back of the car and get someone with skinny arms to reach down past the rear parcel shelf and undo the seat back catches which will alow you to get at the boot latch itslef...you will need to remove three push in clips and pull the trim away from the landing panel then pull outwards the little white lever on the left hand side of the catch as you are looking at it from inside the car...
HOPE THIS HELPS
Old Oct 29th, 2002, 07:01 PM
erazo's Avatar
Send a message via Yahoo to erazo Send a message via Skype™ to erazo
Local Time: 09:18 PM
United States Male View erazo's Dark Silver & White 1st Gen MINI Cooper S Profile
Here2help's technique is RIGHT ON. I had the same problem with my hatch but only after demonstrating the (useless) remote hatch release feature to my daughter, who was not impressed.
Now I NEVER use the remote release, and I no longer have the problem. Poor design!
Old Oct 30th, 2002, 01:48 PM
Thanks for the info - I'll give the re-init a try.
Old Nov 23rd, 2003, 07:41 PM
Local Time: 08:18 PM
United-States
Thanks for the tip....had to remove the rear trim panel and move the white "switch" over. We have a 2002 Cooper S with no remote release.
The thing wouldn't latch. I think I'll end up drilling a hole in the trim panel to better access the white button. Plug it with a trim button or something.
Saved me a trip to the dealer. Really a dumb design.
Old Nov 23rd, 2003, 09:28 PM
notters's Avatar
I had same "no close" problem. After 2 new boot locks neither of which fixed the problem it transpired that the rubber seal around the boot was not seated properly. This meant it was virtually impossible to close boot and extinguish dash warning light.
The rubber seal was refitted .Now works perfectly and closes first time without need to slam the lid down.
Hope this may be of help.
2004 CR/B MCS Chili, MFSW, PDC,Sunroof, CD, Auto A/C
tailgate trim mike ken Second Generation MINI Exterior 0 May 2nd, 2007 06:19 PM
Rust on Tailgate kxl First Generation Faults & Fixes 1 Jun 6th, 2003 02:21 AM
Opening Tailgate the nuke General Discussion 19 Apr 7th, 2003 11:01 PM
smooth tailgate smoothass First Generation MINI Exterior 4 Mar 24th, 2002 04:36 AM
