Windscreen wipers not working - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old May 30th, 2011, 08:20 AM
mab01uk's Avatar
Local Time: 01:55 PM
Quote: Originally Posted by Jinkster (original)
I am having rear wiper issues. Any ideas where to get a new motor (NOT the dealer)? Thanks.
Try these for new or used MINI parts:
www.bmminiparts.com - Home
BMW MINI Spares - Home
Mini Spares Uk - Minispares UK
or
MiniMatt|BMW|MINI|Modifications|Parts|Spares|Servi ce|Tuning|Repairs|Racing
  #17 (permalink)
Old Jan 16th, 2012, 09:06 PM
Local Time: 12:55 PM
common rear wiper problem
hi there - having read this thread i thought i would resurrect it.
My rear wiper does not work - i can hear a small click when it is turned on (Relay?). Fuse seems fine so tried to see if there was power etc to rear wiper when it is turned on but I couldnt work out when power was coming on/off with the meter i was using.
Any other ideas with regard to what might be wrong or is a motor a safe bet.
thanks again - great site!
  #18 (permalink)
Old Jan 23rd, 2012, 02:43 PM
Rear Wiper and Boot lock
Hi People.
Mini Cooper 2005
My rear wiper works when it feels like it! Sometimes when you turn it for one wipe it will go for 7 or 8. Other times it won't work and then start working when its turned off. The water jet always works. Only the other day the boot lock has started popping when you open the car door. It constantly clicks away.
Is this maybe water ingress causing the tailgate electrics to short? All the lights are fine. Where is the earth cable for the tailgate electrics?
If anyone can help I would be very grateful.
  #19 (permalink)
Old Jan 23rd, 2012, 06:47 PM
mab01uk's Avatar
Might be something of help below, water ingress into the tailgate is often from the high level brake light gasket and bad earths or moisture in connectors can create havoc with the Mini's modern 'bus network' style wiring system:
Earth points:
http://www.mini2.com/forum/maintenan...th-points.html
Rear wiper mind of its own:
Rear Wiper has a mind of its own! - totalMINI Forums
Windscreen Wipers Viscount Charles First Generation MINI Exterior 19 Feb 6th, 2009 03:49 PM
Windscreen wipers woody First Generation Faults & Fixes 7 Jan 22nd, 2009 06:11 PM
Windscreen Wipers caesar Second Generation MINI Cooper S 8 Jul 15th, 2007 10:12 PM
Windscreen wipers Gaz-24 General Discussion 9 Apr 15th, 2007 08:40 PM
Windscreen Wipers 118 Maintenance & MINI Care 2 Mar 31st, 2005 07:35 PM
