Lights go dim when i move my steering wheel :( - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 4th, 2010, 06:41 PM
Local Time: 06:33 AM
United Kingdom View boxednfresh's Classified Ads
happy new years before i start :P!
i have noticed recently that when my car is in the parked position, and the front lights on, if i turn my steering slightly, the front lights will go dim for a second. Even when i was driving on the motorway i noticed the front lights going dim when i swithed lanes.
ne1 know whats going on? ne help appreciated
Old Jan 4th, 2010, 07:57 PM
Local Time: 07:33 AM
The power steering is electrically powered, so presume there is some sort of short circuit (that needs expert attention?)
Old Jan 4th, 2010, 09:03 PM
spoke to a mechanic he said it cud be:
1) the battery
2) the alternator
3) the power steering pump (taking too much power or summin)
Old Jan 5th, 2010, 10:26 AM
United Kingdom Male View Silverado's Pure Silver & Body Color 1st Gen MINI One Profile
Another possibility could be a poor contact on the lighting stalk on the steering column. If you move the steering wheel perhaps you affect an electrical contact in the stalk.
I would want to rule it out. Perhaps by moving the steering wheel and lighting stalk with lights on but not the power steering on.
It seems unlikely but easy enough to rule out.
Old Jan 5th, 2013, 02:08 PM
hey, i have the same problem. Did you determine the problem?
Old Jan 6th, 2013, 06:14 AM
bmwr606
Local Time: 01:33 AM
i suspect a bad power steering pump motor
DO NOT DRIVE WITH THE POWER STEERING DISABLED!
to check, pull the power steering fuse/relay, start the car, turn on the lights and turn the wheel while watching for the lights to dim
scott
2012 CM S All4 (03/12) | Abs Black w/White Roof/Mirrors/18" White Wheels | Cold Pkg | Sport Pkg | Xenon w/ Black Housings| Manual | Sport Susp| Anth Headliner | Flat Load Floor | Bluetooth | 2 Part Center Rail | Milltek downpipe back exhaust
Old Jan 6th, 2013, 08:43 AM
mab01uk's Avatar
The power steering draws a lot of power under load, your battery may be failing with age to keep up, how old is it?
Converting a 2 Spoke Steering Wheel to a 3 spoke Multi Function steering Wheel splitboy888 First Generation Interior & Ice 10 Aug 19th, 2012 05:33 PM
Is works steering wheel similar to bmw sport wheel? mcs_sam First Generation MINI Cooper S 11 Apr 28th, 2007 07:09 PM
Lights dim with steering? pob First Generation Faults & Fixes 5 Dec 14th, 2004 11:06 PM
Will my lights dim???? Ibb First Generation Interior & Ice 8 Sep 29th, 2003 10:28 PM
Lights dim when steering at low speed! Varse General Discussion 9 Dec 20th, 2001 11:33 AM
