Electrical Problems.......Please Help!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 23rd, 2010, 12:29 PM
Local Time: 08:49 PM
England Electrical Problems.......Please Help!!
Hi i own a R50 Cooper on a 52 plate and I've got a slight problem!
Yesterday when i was driving along in the rain the ABS, Handbrake and Run Flat lights all flashed on for about 5 seconds with the Run Flat light staying on. The Temperature needle shot up again for 5 seconds and the Rev & Speedo Dial dropped to zero again for 5 seconds. This happenend about 10 times in a 3 mile journey!
The car continued to run as normal. When i stopped and turned the ignition on and off all the warning lights went off.
Any help/solution would be much appreciated.
Thanks Tony
Old Jan 23rd, 2010, 05:56 PM
mab01uk's Avatar
Online
Local Time: 07:49 PM
Have the battery/alternator output checked first, if it is the original battery it will be nearing the end of its life and they can cause random electrical faults on Mini's when they start to fail.
Bad/corroded wiring earth points and moisture/water in any electronic modules like the BC1 (Body Control Module) can also cause problems if you do a search on here.
BC1 Link:
The BC1 (Body Control Unit) - Mini Torque
Tags: , ,
Electrical problems xlol88 First Generation Faults & Fixes 2 Dec 27th, 2009 03:57 PM
Help Electrical Problems Tweedbean First Generation Faults & Fixes 4 Apr 26th, 2009 09:15 PM
electrical problems april1983baby First Generation Faults & Fixes 4 Dec 21st, 2008 03:29 AM
Electrical problems Saad First Generation Interior & Ice 3 Sep 14th, 2008 10:43 PM
Electrical Problems Jenny G First Generation Faults & Fixes 0 Jul 9th, 2008 09:09 PM
