| ABS Unit packed up - which one fits? Hi, 09/2002 Mini Cooper 1.6. I recently lost brakepressure in the whole system. First inspections showed that the RightRear brakes are not getting any fluid. The ABS light didnt go on eventhough its working. Car doesnt want to connect to diagnostics computer at BMW workshop. Tried bleeding the system first per hand and then with a machine to no avail. The valve for the RR brake in the Abs modulator(? that aluminum part of the unit) seems to be shut though as I understand it should be open when not under power. 1. Can I use any ABS unit for modelyears 2002-06 on my car irrespective of S or Non-S? 2. Can i temporally bypass the abs system? By either connecting the RR circuit to the LR circuit or completely bypass it for all 4 wheels? Any help is appreciated. Thanks. PS: In in the market for a new unit. See Wanted section. |
| Try here for a secondhand ABS unit or ebay: Mini Spares UK - Home OR MiniMatt|BMW|MINI|Modifications|Parts|Spares|Servi ce|Tuning|Repairs|Racing If you enter your MINI chassis number in here you can compare part numbers: RealOEM.com BMW R50 Cooper ABS hydro unit/control unit/support |
| Tags: abs, brakes |
| abs control unit | oscar.cat | First Generation Faults & Fixes | 0 | Jul 29th, 2009 12:22 PM |
| Pressure washer packed in | Tweedbean | Maintenance & MINI Care | 3 | Feb 3rd, 2009 04:29 PM |
| JCM brake vent kit and racing ABS unit | Dwnshift | Wheels, Tyres & Brakes | 18 | Sep 9th, 2008 10:12 PM |
| ABS Control Unit Failure | allyjm | Second Generation MINI Cooper | 4 | Oct 17th, 2007 04:40 PM |
| ABS CONTROL UNIT replacement - out of warranty | trucker | First Generation Faults & Fixes | 1 | May 1st, 2006 05:49 PM |
