Gravel sound coming from gearbox - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 15th, 2010, 06:07 PM
Local Time: 05:10 PM
Canada
Hi! I have a 2002 mini cooper 1.6L Automatic transmission. I took the car in to a local garage and a mechanic noticed a rattling/gravel sounding noise coming from the gearbox area when the cars front wheels are manualy turned while the car is in neutral. He does not seem to know the cause. Can anyone please help? Thanks.
Old Mar 16th, 2010, 07:17 AM
Sejanus's Avatar
MINI2 Global Moderator
Local Time: 02:10 PM
United States Male View Sejanus's Chili Red & White 1st Gen MINI Cooper Profile
Not sure about the cause, but you don't have an automatic transmission if your car is an '02, you have a CVT
(Continuously Variable Transmission). If you hear a rattling noise while driving that usually means the CVT is about to fail and they are very expensive to replace. I would take it to a MINI dealership and have them check it out.
Old Mar 16th, 2010, 08:33 AM
Canada
Thanks, you are right it is a CVT. However I do not hear the noise while I am driving, and the CVT changes the gears smoothly. I did have a problem with the CVT last summer where it would not change gear properly between 50-70km/h, and knobody seemed to know what was causing the problem. Everyone said that everything seemed ok. Anyways, I later replaced the battery and the CVT has not worked fine ever since (so far 5000km since then). As for the noise from the gear box ... the noise was there last summer also (not sure if it is worse at all). I would assume that if the CVT was about to go, that I would notice somethign now while I am driving. As I said I can only hear the noise when the car is in neutral and lifted up off the ground and rotate by hand either of the front 2 wheels.
Old Mar 16th, 2010, 08:41 AM
Canada
I did talk to a couple mini cooper mechanics over the phone, of course they said that they can not tell me exactly what the cause is. However, one told me that maybe it is the Axel ... however that I doubt since it would take a lot to break it, and the mechanic I took the car in to would have noticed I would assume. The other mechanic mentioned that it might be the transmission mounts or the power steering rack.
Tags: , ,
water sound coming from my dash bigpoppa81 First Generation Faults & Fixes 4 Dec 20th, 2011 01:03 PM
Buzzing sound coming from the Speedo N20 First Generation Faults & Fixes 6 Mar 13th, 2007 07:03 AM
Nasty sound coming from—I believe—the wheel(s) VWY First Generation Faults & Fixes 0 Jun 8th, 2005 02:41 AM
Weird sound coming from the engine... MiniMan7 First Generation Faults & Fixes 13 Nov 19th, 2003 02:40 PM
Where is the ding sound coming from? mikkol General Discussion 4 Mar 28th, 2003 07:29 AM
