Noise from front of car - please help diagnose! - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Mar 22nd, 2010, 04:55 PM
Local Time: 12:57 PM
DIY Squeaking problem
Omg!i bought my mini cooper last week! everytime i put the car on it squeaks until it is warm whichmeans when i go from home to work everyday it squeaks all the way because itsonly 3 miles! and when i go home cz its cold again it squeaks again!its soooo annoying and sounds really loud!what could it be??its really annoying!also there is a ratling from the front wheel!ifits a bearing shouldnt that have been sorted out before passing the MOT?ive only had it a week today!!??
Can some one helpme!!!
  #17 (permalink)
Old Mar 22nd, 2010, 05:14 PM
dan_cooper_s's Avatar
Local Time: 01:57 PM
United Kingdom Male View dan_cooper_s's Classified Ads
3 Miles!!! Why dont you walk?
  #18 (permalink)
Old Mar 22nd, 2010, 07:34 PM
redlinepete's Avatar
Wales Male View redlinepete's Classified Ads
I had a little play with the clutch.....this is what I did just so I could report back..... Put the car into first gear....Make sure the hand brake is on hard....Rev the engine and let the clutch out slowly ..Don't stall it then press the clutch .....Tell us what happens???
  #19 (permalink)
Old Mar 22nd, 2010, 09:40 PM
noise when pulling off .
Quote: Originally Posted by cokey (original)
Ive got an 03 MCS. Started getting a noise from the front of the car, when pulling off from staitonary. The noise was the sort of moaning noise a bus makes when braking, much quieter though. The last service mentioned that the front brake pads and discs needed replacing, so I assumed this was the cause of the noise. Had them changed out a couple of weeks ago but the noise has not gone away.
I then assumed that the brake calipers were maybe seizing and sticking the pads to the discs after braking, therefore making the noise when I pull off. I took it to a mechanic that I'm aquainted with, but it seems that the noise is hard to replicate after the car has been driven for a few miles (the journey was 30 miles/45 mins). He told me to try and pinpoint where the noise is coming from, when it next happens. He was very busy and couldn't really offer much more, other than he'll be able to look at it properly in about 3 weeks.
I took the car back to work and left it for 5 hours. I then got a couple of colleagues to stand either side of the car as I pulled off, backwards and forwards. They are both sure that the noise is eminating from the front but it doesn't seem to be coming from a particular side. Beacuse the noise dosen't seem to come from one particular wheel, I'm now wondering if the problem isn't the calipers (unless both front calipers are seizing). What else could cause this type of noise? As I said the noise is like a quietened down version of a bus braking, a moaning noise. It also seems to happen more if I'm pulling off and turning at the same time, and happens whether Im going forwards or reversing.
One other thing that the last service mentioned was that the Control Arm Bushings need replacing. Mentioned this to the mechanic, he did some braking, backwards and forwards but said that it didnt feel like they need to be urgently changed. Could these bushings be causing the noise? Mechanic didn't think so but I'd be interested to hear oppinions from the group.
Thanks in advance for any help
Marc
could be your power steering pump.
  #20 (permalink)
Old Mar 24th, 2010, 09:36 PM
cokey's Avatar
United Kingdom View cokey's Classified Ads
Yep, did exactly that. When I let the clutch out a certain amount, the noise begins and continues until I dip the clutch again!
I can now pull off without the clutch making the noise but I have pull off very gently and smoothly. Even after a 45 min drive I can still sometimes get the sound by pulling off aggressively!
  #21 (permalink)
Old Mar 25th, 2010, 04:06 AM
philz's Avatar
United Kingdom View philz's Classified Ads
I have the same issue with my 2006 R53, anyone managed to get a definitive diagnosis of what causes it?
  #22 (permalink)
Old Mar 25th, 2010, 12:57 PM
cokey's Avatar
Interesting thread on the problem here: http://www.mini2.com/forum/first-gen...st-gear-3.html
If mine was still under warranty I would be insisting they sort the problem out. Guess I'm just going to have to live with it for now, until something gets worse...
  #23 (permalink)
Old Apr 2nd, 2010, 01:01 AM
Local Time: 07:57 AM
Hello all I have an 05 S that has the same symptoms of grinding while turning and while taking off however mine is also pulling to the left or right on occasion while braking. Also even after driving for an amount of time the sound does not go away but remains there. The warranty just expired on the car and I would like to avoid going into the dealer without some knowledge of what is wrong. Front brake pads and discs are new on the car.
  #24 (permalink)
Old Apr 2nd, 2010, 01:11 AM
05 Mini Cooper S grinding noise
Marc.
I have also noticed that the clutch pedal faintly squeaks and feels as though it is hanging up during the first couple of inches in travel and is fine after that. Lubricate pedal?
Thanks all,
Brian
  #25 (permalink)
Old Apr 2nd, 2010, 09:20 AM
DaFlake's Avatar
MMC Member
Local Time: 08:57 AM
Where are you located? We might be able to suggest someone that can take care of you at a better price than a dealer.
  #26 (permalink)
Old Apr 9th, 2010, 01:22 PM
philz's Avatar
I recorded the noise this morning when I got my car out of the garage, does it sound like yours?
  #27 (permalink)
Old Apr 13th, 2010, 10:23 AM
cokey's Avatar
Yep, mine sounds very much like that.
  #28 (permalink)
Old Apr 13th, 2010, 10:59 AM
Mine is identical to that too!
Its going into the garage this thursday to get it looked at and hopefully sorted out under warranty. Ill let you know how I get on.
  #29 (permalink)
Old Apr 13th, 2010, 12:14 PM
It's the clutch....can you feel the vibration through the clutch pedal?...I know it sounds like the brakes sticking on...But it's not...If you reverse out get the car moving then the sound is there ...Dip the clutch ...It's gone..It's a strange one I agree... It happens when there is load on the clutch as when taking off...It's as if the clutch is trying to grip the flywheel and not quite making it then the springs work then no sound.
Tags: , , , , , ,
front suspension noise the mask Second Generation Faults & Fixes 0 Oct 24th, 2009 10:15 PM
whirrring noise from the front BlackEyedPea First Generation Faults & Fixes 1 Mar 3rd, 2008 08:28 PM
Can anybody diagnose this? MickCooperS First Generation Faults & Fixes 0 Oct 28th, 2007 04:34 PM
high speed noise from front of car...... andy999 First Generation MINI Cooper S 12 Oct 29th, 2006 10:35 AM
Grinding noise - front left Zooloo First Generation Faults & Fixes 4 Apr 9th, 2005 03:09 PM
