Ive got an 03
MCS. Started getting a noise from the front of the car, when pulling off from staitonary. The noise was the sort of moaning noise a bus makes when braking, much quieter though. The last service mentioned that the front brake pads and discs needed replacing, so I assumed this was the cause of the noise. Had them changed out a couple of weeks ago but the noise has not gone away.
I then assumed that the brake calipers were maybe seizing and sticking the pads to the discs after braking, therefore making the noise when I pull off. I took it to a mechanic that I'm aquainted with, but it seems that the noise is hard to replicate after the car has been driven for a few miles (the journey was 30 miles/45 mins). He told me to try and pinpoint where the noise is coming from, when it next happens. He was very busy and couldn't really offer much more, other than he'll be able to look at it properly in about 3 weeks.
I took the car back to work and left it for 5 hours. I then got a couple of colleagues to stand either side of the car as I pulled off, backwards and forwards. They are both sure that the noise is eminating from the front but it doesn't seem to be coming from a particular side. Beacuse the noise dosen't seem to come from one particular wheel, I'm now wondering if the problem isn't the calipers (unless both front calipers are seizing). What else could cause this type of noise? As I said the noise is like a quietened down version of a bus braking, a moaning noise. It also seems to happen more if I'm pulling off and turning at the same time, and happens whether Im going forwards or reversing.
One other thing that the last service mentioned was that the Control Arm Bushings need replacing. Mentioned this to the mechanic, he did some braking, backwards and forwards but said that it didnt feel like they need to be urgently changed. Could these bushings be causing the noise? Mechanic didn't think so but I'd be interested to hear oppinions from the group.
Thanks in advance for any help
Marc
