Yellow Engine warning light - MINI Cooper Forum
post #1 of 5 (permalink) Old Mar 27th, 2010, 06:54 PM Thread Starter
Texy's Avatar
Local Time: 03:35 AM
England
Hi,
last year my 54 plate MCS engine emissions light came on for a week or so, then went out. It continued to come on/go off for a couple of months with no other problems with power, consumption etc etc. I mentioned it to the garage when it went in for its service in November. They cleaned up the connection to the sensor and it was fine for a while, but has come back again. Does anyone know exactly where it is, or can provide a picture please? I,d like to take a look at it myself, maybe even change the sensor if its easy enough to do.
Cheers,
Texy
Texy is offline
post #2 of 5 (permalink) Old Mar 27th, 2010, 07:08 PM
mab01uk's Avatar
Local Time: 02:35 AM
Quoted: 1 Post(s)
The oxygen/lambda sensors are screwed into the exhaust, one before the Cat and one after. Check the wiring connections or one or both may need replacement or the Cat could be at fault among other things. Any garage which does MOT's will be able to check your emmisions, etc for you.
mab01uk is offline
post #3 of 5 (permalink) Old Mar 27th, 2010, 07:46 PM Thread Starter
Texy's Avatar
England
Thanks for that. The car had MOT when it was serviced, and as the car is performing as normal, I,m not too concerned that it'll be anything major. In fact I,ve just got the best consumption I,ve ever had on this or my previous MCS - 39.2mpg over a full tank (according to the trip 'puter). I was driving like a granny for the week however!
I would still like a better idea of where they are though - are they under the car, ie I,ll need to jack it up, or on top, so under the bonnet?
Texy
Texy is offline
post #4 of 5 (permalink) Old Mar 28th, 2010, 06:45 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Follow the exhaust manifold from the engine until you see the Cat, they are Lambda Probe No. 8 as shown on this diagram:
RealOEM.com BMW R53 Cooper S Exhaust manifold with catalyst
Ensure no oil or dirt gets on the tips of the sensors if you unscrew them but you won't need to if you just check the wiring connection is clean and tight.
mab01uk is offline
post #5 of 5 (permalink) Old Mar 29th, 2010, 09:38 AM Thread Starter
Texy's Avatar
England
Cheers mate - I,ll take a look.
Texy
Texy is offline
R56 Overload indicator light, no water in engine issues LadyUK Second Generation Faults & Fixes 1 Nov 13th, 2013 05:26 PM
Warning light? Seeg Second Generation Faults & Fixes 1 Mar 11th, 2013 06:19 PM
Pls help re tyre pressure issue (+ warning light)... halesowenmum Wheels, Tyres & Brakes 8 Jan 25th, 2013 09:39 PM
Failed oil warning light may have cost me BIG TIME!!! olly-w First Generation Faults & Fixes 8 Dec 18th, 2012 01:46 PM
1st Generation One engine warning light mrlines First Generation Faults & Fixes 4 Nov 17th, 2012 08:42 PM
