Help with p1237 code - MINI Cooper Forum
post #1 of 2 (permalink) Old Apr 18th, 2010, 04:27 PM Thread Starter
xboss
Local Time: 03:57 PM
United States Male
Hi All…
I recently bought a slightly used 2005 JCW with about 30k on it, awesome car I had forgotten how much fun driving can be. I have found very few issues with it but it is having a reoccurring P1237 code that points to secondary upstream manifold air pressure sensor low input, has anyone got any info on where this sensor is located ? or had any experience with this fault, I cant find any loose vacuum hoses etc.
xboss is offline
post #2 of 2 (permalink) Old Apr 20th, 2010, 04:09 PM Thread Starter
xboss
United States Male
OK.. I figured out where the sensor is and found the connector had a wee bit of corrosion, a bit of electronics cleaner and cleared the code..all is well.. cheers
xboss is offline
Radio Code Reset Arikax89 First Generation MINI Cooper 4 Nov 8th, 2015 11:57 AM
Code P0014 is messing me up and won't go away...help!!! TonyE Second Generation Faults & Fixes 2 May 21st, 2014 06:47 PM
Engine light (O2 sensor code) Florence & machine Second Generation Faults & Fixes 2 Feb 2nd, 2013 04:37 PM
