Ticking sound untill clutch is depressed first time - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 30th, 2010, 01:05 PM
3rdpillar's Avatar
Local Time: 12:57 PM
United Kingdom Male View 3rdpillar's Chili Red & White 1st Gen MINI Cooper S Profile
06 MCSC
When you start the car there is a definite ticking, clacking noise from the engine bay. That is untill the clutch is depressed then it completely goes away.
Next time you stop and start the car ( say after 30 mins ), the ticking/clacking is back, again only till the clutch is depressed.
Any ideas, other than cheer up the clutch?
__________________
Old May 2nd, 2010, 07:11 AM
Mike Edwards's Avatar
Local Time: 01:57 PM
England View Mike Edwards's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View Mike Edwards's Classified Ads
Probably the clutch release bearing rattling. WHen you depress the clutch the bearing is then pushing against the pressure plate of the clutch (so it cant rattle). When you release the clutch it's all nicely in line (so tends not to rattle).
Not really a problem - even if it starts the rattle everytime you're sat in neutral.
Old May 2nd, 2010, 04:23 PM
Spoony's Avatar
Send a message via MSN to Spoony
England Male View Spoony's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Spoony's Classified Ads
Yep, clutch release bearing. Not massively expensive to fix
Tags: ,
ticking sound when running Scrounger Second Generation Faults & Fixes 10 Sep 25th, 2009 12:41 PM
Engine ticking when clutch depressed MiniSpeed First Generation Faults & Fixes 4 Jul 26th, 2008 12:56 PM
Ticking when clutch not engaged Quentin First Generation MINI Cooper S 17 Apr 1st, 2004 10:01 PM
ticking sound No Golf Clubs at all First Generation Faults & Fixes 2 Nov 3rd, 2003 11:02 PM
Ticking sound at start up jbramhall First Generation MINI Cooper S 6 Jul 9th, 2002 07:23 AM
