| Here are some pictures showing the green clips. I tried to get one out and snaped it, I put it back in though and had to glue it. Ignore the glue mess! I havent glued it, I pulled it all off now. The white clips on the panel are the ones that have snapped. So anyway going to try and order some new clips and get it back on properly. Didnt really take any useful photos stupidly, although I took a picture of the foam gaskets. On my car there was no gasket there, just one tiny piece at the top, so it might do something. UPDATE* Never mind, I found this: http://www.northamericanmotoring.com...rim-piece.html Obviously my nuts stayed in the holes because they were tight ![]() Also note the foam gasket in that post, that is the OLD style, probably prone to water leaks. See my attached gasket to the newer style, dunno if it makes any difference. Im ordering part 17 on here http://www.realoem.com/bmw/showparts...75&hg=51&fg=20 Last edited by solidsponge; May 7th, 2011 at 06:43 PM. |
| Hi, i recently bought a mini cooper 2003 plate. I need the front panel replaceing however i found a cooper s one of a 2003 plate car and was wondering if it would fit??? Does ant one have an idea of wether there are diifferent Thankssssssssssss |
| If the 'front panel' you're referring to is the A-Pillar outer trim as mentioned above then they're identical. There's an online catalogue of All MINI spares listed here covering EVERY model >> RealOEM.com Online BMW Parts Catalog {Yours is an 'R50' & the Cooper S of that year has the designation 'R53' if you need to cross-check anything} Full breakdown of designation numbers HERE ![]() |
| Tags: a pillar trim, fixing water leaks |
| Gutter trim above A-pillar | Makka Pakka | First Generation Faults & Fixes | 7 | Aug 8th, 2010 11:28 AM |
| Looking for O/S Outer Pillar Trim | S40TYD | First Generation MINI Exterior | 1 | Mar 21st, 2010 04:37 PM |
| A pillar trim | philip rodney | First Generation Faults & Fixes | 2 | Nov 1st, 2005 06:37 PM |
| B Pillar Panel Removal HELP | IMAXMINI | First Generation Interior & Ice | 2 | Apr 23rd, 2003 07:49 AM |
| B pillar interior panel removal..HELP | IMAXMINI | First Generation Faults & Fixes | 0 | Apr 20th, 2003 12:42 AM |
