possible power steering pump failure - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 7th, 2010, 05:08 PM
Woolly44's Avatar
woolly
Send a message via MSN to Woolly44
Local Time: 01:58 PM
United Kingdom Male View Woolly44's Classified Ads
Hi, Last week I noticed my power steering pump had gone silent and the steering became intermittently heavy, after turning off the car and then driving it again an hour later the power steering was fine. However a few days later the pump has gone totally silent and there is no assistance with steering at all. I checked fluid levels and pipes for leaks and all is fine, I then removed the pump and took it apart to check for wear or bad electrical connections, I span the pump side with a screwdriver and allowed fluid to run through the pump and all was fine. The only visible problem I could see with the electrical side of the pump was a build up of dust however I just took this as wear on the magnetic plates that surround the coil. I put the pump back and bleed the system and the pump is still failing to work, however when the car is first started the pump works for about 3 seconds and then cuts out again. Can anyone distinguish if I need a new pump or I have a simple wiring fault somewhere along the line? Has anyone had symptoms like this?
Old Jun 7th, 2010, 06:33 PM
mab01uk's Avatar
Sounds like you may have to get a recon pump in the end, read through all the info and link below as something may help you:
Power Steering Pump replacement - Forums
Tags: , ,
Power steering failure help! Pump still running! mrsherbie First Generation Faults & Fixes 25 Jul 13th, 2009 01:18 PM
Power Steering Pump failure - the solution ratherbewindsurfing First Generation Faults & Fixes 0 May 5th, 2009 10:45 PM
Power steering pump with failure masha First Generation Faults & Fixes 4 Apr 24th, 2009 08:46 PM
Power steering leaks, then pump failure zimzaf First Generation Faults & Fixes 3 Mar 25th, 2009 08:47 PM
2006 Cooper - CVT Auto Transmission Failure #2 & Power Steering Pump Failure - Why??? Joe Z First Generation Faults & Fixes 17 Feb 18th, 2006 12:33 AM
