Emisson light wont come off - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 23rd, 2010, 10:39 PM
Local Time: 02:58 PM
Norway View Alfa Veloce's Classified Ads
Hi guys
I've put on a de-cat pipe on my MCS and the emisson light came on after a few days..
I saw that this is also a problem sometimes when fitting sports-cat and that I could disconnect the post-cat lambda to get rid of the light..
I've disconnected it and disconnected the battery for around 15min since it didnt disappear at once.. But its still on!
Am I doing something wrong?
Old Jul 6th, 2010, 03:21 PM
Anyone??
Old Jul 6th, 2010, 06:28 PM
mab01uk's Avatar
Local Time: 01:58 PM
I would try asking on Totalmini.com or MiniTorque.com
Old Jul 6th, 2010, 08:44 PM
DaFlake's Avatar
MMC Member
Local Time: 08:58 AM
You tossed a code and it will likely have to be cleared with a reader for it to go out. Doing what you did you keep it out but from what I have heard the MINI does not run well without a cat as it needs that back pressure.
Old Jul 7th, 2010, 06:59 PM
Thanks for the tip, but regarding the back pressure etc, I can confirm to you that it's not the case, my MINI doesnt run any worse, quite the opposit
I mounted the Janspeed manifold with Janspeed de-cat pipe and Simons stainless "cat-back" exhaust, sounds fantastic and run quite well! A combination I'm not afraid to recommend to other R53's
I'll try to get the faultcode deleted and then see what happens
Old Jul 7th, 2010, 08:20 PM
DaFlake's Avatar
MMC Member
Doesn't matter to me as I won't run without a cat. Here it is the law (as i suspect it is there as well) and it simply isn't good for the environment.
Old Jul 8th, 2010, 08:36 AM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
As above basically...
The light can turn itself off if run under 'normal' conditions for a while however, but if running decat it will stay on... mine comes on now and again and im running a sports cat, under certain circumstances it will go off again - normally driving hard turns it off, which makes me laugh...
Decat is basically for noise only on the mini - causes problems with the light, makes the exhaust very raspy, and it will loose you boost pressure and hence power and torque... I lost 5whp on a back to back test (note thats at the wheels)...
Basically the decat will loose you any power you gained from adding the performance manifold
Running 211whp
Tags: , ,
Help it wont come off ! pontyperv First Generation Interior & Ice 2 Feb 13th, 2006 02:23 PM
Flashing light means top wont open. mxyzptlk First Generation MINI Convertible 12 Jan 27th, 2006 05:31 AM
My S wont run!! AlBundy First Generation MINI Cooper S 3 Mar 4th, 2005 05:47 PM
Airbag warning light on - airbags wont deploy? Paul First Generation Faults & Fixes 20 May 22nd, 2003 03:10 PM
wont start!!! IAN ELLIOTT First Generation Faults & Fixes 5 Feb 24th, 2003 06:32 PM
