My passenger window won't go down! - MINI Cooper Forum
LinkBack Thread Tools Rating: Thread Rating: 5 votes, 5.00 average.
post #1 of 29 (permalink) Old Jun 30th, 2010, 02:10 AM Thread Starter
Minette's Avatar
Local Time: 08:23 PM
Black Cooper My passenger window won't go down!
Hi, I have a 2003 Mini Cooper, and the passenger window just stopped going down. It's not the fuse. Help!
Minette is offline
post #2 of 29 (permalink) Old Jun 30th, 2010, 02:45 PM
Soopercooperinfo's Avatar
Local Time: 02:23 AM
United States View Soopercooperinfo's Pepper White & Black 1st Gen MINI Cooper S Profile
Found this --hope it helps-good luck. http://www.mini2.com/forum/first-gen...t-working.html
06 MCS PW/B, 15% pulley, JCW CAI, ALTA 22mm rear sway bar, DINAN front strut tower brace, custom air diverter plate, original owner.
Soopercooperinfo is offline
post #3 of 29 (permalink) Old Jun 30th, 2010, 03:51 PM
cokey's Avatar
Local Time: 03:23 AM
Quoted: 1 Post(s)
United Kingdom View cokey's Classified Ads
Can you still hear the relay clicking when you try and open the window?
If so then it's a very common problem. Seems to be caused by the small movement that the window does whenever you open or close the door, causing a flat spot in the motor, therefore it gets stuck.
It's possible to get it going again by thumping the door panel with your fist (or better still a rubber mallet), just above the large speaker (the motor is behind here).
It worked for me on my failed passenger window and it's still working 6 months later! This method has worked for countless other people too.
I've copied the exact instructions that I used from another post:
With the car in aux or on -- sit in the seat with the door open.
Press and hold the window switch up
Immediately, while holding the window up toggle -- with your fist -- punch / hit three inches above the large speaker -- three times. <bang bang bang>. Don't be easy on your MINI.
Let go of the toggle switch.
Press and hold the toggle switch up for 5 seconds.
Lower the window completely.
With the door still open
Raise the window completely. The window should have now "re-indexed" itself.
In case the indexing didn't work -- it would be wise for you to lower the window just slightly before closing the door.
Close the window.
Good luck and please report back whether it worked or not!
cokey is offline
The Following 10 Users Say Thank You to cokey For This Useful Post:
post #4 of 29 (permalink) Old Jul 1st, 2010, 06:36 PM
Hoodwinkedbast
Just came on here to post exactly the same problem with my drivers side window.
Followed Cokey's instructions in the above post. It took 3 or 4 goes with the thumping getting harder each time but this did work!!
Thanks!!
hoodwinkedbast is offline
post #5 of 29 (permalink) Old Jul 2nd, 2010, 11:12 AM
cokey's Avatar
Quoted: 1 Post(s)
Glad to hear it worked for you. Can't actually take credit for the instructions as I found them elsewhere. First time I tried, it didn't work but thumping harder did the trick. Make sure you open and close the window on a regular basis, to keep the motor from sticking again.
Word of warning to anybody doing this 'thump fix' - don't hit the panel so hard that you damage it. I read of somebody actually punching though it (I think it's made of particleboard or something)
cokey is offline
post #6 of 29 (permalink) Old Jul 9th, 2010, 12:36 AM
Local Time: 09:23 PM
If only we could fix the power steering pump this way!
$900 for a new power steering pump installed. 3 thumps with my fist would have been a lot cheaper!
tomasme is offline
post #7 of 29 (permalink) Old Aug 19th, 2010, 12:20 PM
England
Omg I thought it was a crazy idea punching the door but to my shock It worked thanks :-)
Chris-minicooper is offline
post #8 of 29 (permalink) Old Aug 23rd, 2010, 05:54 AM
MINI on the brain!!!
85NIXMIN's Avatar
Local Time: 12:23 PM
Australia Female View 85NIXMIN's Midnight Black & Silver 2nd Gen MINI Cooper S Profile
You were lucky my 2003 MINI Cooper had this problem... ended up getting a new motor put in under warranty!
03 BLACK MC, 05 BEP MCC, 07 BLACK MCS, 09 PW MCSC, 12 MB MCSCoupe
85NIXMIN is offline
post #9 of 29 (permalink) Old Mar 23rd, 2012, 12:59 AM
Thank you for the thump fix it really works ... so happy as I wont need to wake up extra early to take it to the garage before work =)
LBjackmini is offline
post #10 of 29 (permalink) Old Mar 23rd, 2012, 09:24 PM
England
This technique has worked on my car a few times. When I tried it this time it didn't seem to work, but 3 days later I was able to open the window.
minimad1970 is offline
post #11 of 29 (permalink) Old Mar 24th, 2012, 01:49 AM
I just bought an 02 Cooper. Advertised at 3000. Got 200 knocked off because passenger window didn't work and passenger side front bearing noise. Bearing cost me 66 and window worked with a few good thumps. Bargain
mattberkshire is offline
post #12 of 29 (permalink) Old Mar 24th, 2012, 09:09 AM
My other halfs N\S windows is doing this as well, might go out and give it a good punch today.:-)
staningrimsby is offline
post #13 of 29 (permalink) Old Mar 24th, 2012, 02:59 PM
Well what do you know it worked, the missus is well happy now :-)
post #14 of 29 (permalink) Old Mar 25th, 2012, 06:10 PM
hanoi's Avatar
View hanoi's Pure Silver & Body Color 1st Gen MINI One Profile
I will have been doing this for 10 years next month.
The window motor often gives up the ghost when the weather is hot.
hanoi is offline
post #15 of 29 (permalink) Old Jun 6th, 2012, 06:14 PM
Minato's Avatar
Hey ladies and gent , i`ve gotta say thanks to you all, had same problem on cooper s for last few weeks , first wouldnt go down then it mush of dropped slightly so was getting wind noise, 3-4 smacks and sorted it , i nearly went in to mini dealers today, so glad ididnt , god knows what theyd of charged me
Minato is offline
Tags: ,
passenger window jtg91 First Generation Faults & Fixes 6 Aug 12th, 2009 01:04 PM
Passenger window the-ruff-puppy First Generation Interior & Ice 6 Jul 26th, 2006 06:56 PM
Passenger Window Chapmoni First Generation MINI Cooper S 10 Jan 16th, 2004 08:38 PM
Passenger window goes down but not up... ZekaFon First Generation Faults & Fixes 2 Nov 4th, 2002 09:55 AM
Passenger Window Bonnie Scotland First Generation MINI Cooper S 2 Sep 15th, 2002 08:28 PM
