Fan running after shutting off car - MINI Cooper Forum
post #1 of 6 (permalink) Old Jun 30th, 2010, 10:59 AM Thread Starter
Yuf's Mini's Avatar
Local Time: 12:26 AM
Australia Male
Hi
I have a 2006 Mini Cooper Cabrio S. I live in Melbourne Australia.
In the last year, only a handful of times I've experienced the fan running after the ignition is turned off.
However, in the past couple of weeks, the fan kicks in almost every time after turning off the engine.
In addition, when driving, and idling at a red light, the temperature gauge will shoot up and redline, but with the fan kicking in on high, it will eventually drop back down. Or once I start driving again, it will drop down to middle again.
I will check the Coolant level in the morning, hopefully I find that it is low, and this is causing the temperature to redline.
If this is the case, do I need to purchase special coolant from Mini? Or what should I be looking for? Is this something I can top up myself?
Or should I take it in to Mini to let them top it up and flush etc?
thanks,
yuf
Yuf's Mini is offline
post #2 of 6 (permalink) Old Jun 30th, 2010, 12:31 PM
Local Time: 02:26 PM
Quoted: 1 Post(s)
United Kingdom Male View steeve's Classified Ads
When you shut off the engine the coolant stops circulating, consequently the heat from the block transfers into the coolant in the block and head raising the temperature significantly, its enough to trigger the fan to switch on until the temperature drops. Designed to do this, happens more in hot weather or if you have been driving hard.
steeve is offline
post #3 of 6 (permalink) Old Jun 30th, 2010, 05:42 PM
View maybury's Classified Ads
I find this happens every now and then to my car (fan coming on after the ignition is off) but im sure there is nothing to worry about but about your temperature gauge hitting the red mark, this happended to me I took my car to BMW and they said that the thermostat and the housing will have to be replaced replaced (luckly under warranty) and the problem has not happend since.
maybury is offline
post #4 of 6 (permalink) Old Jun 30th, 2010, 10:22 PM
Overly excited!!
Bhozar's Avatar
Local Time: 03:26 PM
United Kingdom Male View Bhozar's Electric Blue & White 1st Gen MINI Cooper S Profile View Bhozar's Classified Ads
It's very bad news if the temp gauge is hitting redline often. The gauge doesn't really have any scale to it, it's either warming up, in the middle or overheating. Get it looked at ASAP. You dont want to keep doing that in case you warp your cylinder head or worse.
My fan often comes on after I have been driving enthusiastically and then get stuck in slow traffic or park up. Never any other time.
14.438 @ 98.53
Bhozar is offline
post #5 of 6 (permalink) Old Jul 1st, 2010, 04:34 AM
trust me, I'm a doctor...
im_dave's Avatar
Australia Male View im_dave's Dark Silver & Black 1st Gen MINI Cooper S Profile View im_dave's Classified Ads
Funny you should mention. I have a 2004 (MY05) MCS with the exact same problem in Melbourne. I have taken it into BMW Doncaster who have said that it is a faulty thermostat which needs to be replaced (~$450 she quoted me)... it is currently getting fixed as we speak so hopefully that is it. I have also read that it could be the low speed radiator fan not functioning properly due to ?faulty fan or ?faulty fuse. Best to get it checked.
long live the supercharger
im_dave is offline
post #6 of 6 (permalink) Old Jul 1st, 2010, 09:35 AM Thread Starter
Yuf's Mini's Avatar
Australia Male
Thanks everyone. I have looked into the Mini Manual booklet - and under Coolant - it gives a bit of basic info (locating where the Coolant goes). I've opened up the cap to where the Coolant is housed and found that it was very low (bottom end of minimal).
I then called BMW Brighton and they said to just top it up with water. They recommend topping up with water between services - and they do the full flush and add new coolant at the time of service.
I've driven the Cabrio S today - and so far so good. The fan has not kicked in high at all. Fingers crossed this is the extent of it. Will check it in a weeks time to make sure there's no leakage of coolant.
Cheers.
Yuf
Fan keeps running when car off! kingjayson1 First Generation Faults & Fixes 5 May 1st, 2010 11:21 PM
Fan running after shutting off car. Normal? cheswick Second Generation Faults & Fixes 4 Nov 30th, 2009 04:31 PM
Fan running after engine is off? themoose333 Second Generation MINI Cooper 3 May 8th, 2007 12:28 AM
PS fan not running Zipperblues First Generation Faults & Fixes 3 May 22nd, 2006 02:13 AM
Fan running after engine is off? andrewyang General Discussion 4 Oct 5th, 2002 10:42 AM
