ABS Problem - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 11th, 2010, 05:12 PM
Rudolph Hucker's Avatar
Local Time: 01:59 PM
England
Exclamation ABS Problem
After upgrading my brakes ON MY R53 to R56 JCW all round, now have a situation where, under normal braking, the ABS cuts in even at low speeds causing a judder as the braking is interrupted and dramatically reducing the braking effect, not very nice in traffic! Eventually the ABS, TractionControl and Tyre pressure lights come on and normal braking is restored, I guess in 'Safe mode'.
Sometimes, hitting a speedbump will trigger the warning lights.
I haven't tried to see if the ABS or Traction Control still works when the warning lights are on, maybe I'll go out later and try.
Tags: , ,
Tyre Pressure, Abs and Traction Control light problem tompat3463 First Generation Faults & Fixes 7 Apr 27th, 2012 11:34 PM
Think I know what the problem is with our ABS sytems tompat3463 First Generation Faults & Fixes 0 Apr 26th, 2010 08:33 AM
Brake / Abs suspected problem iand123 Wheels, Tyres & Brakes 8 Sep 11th, 2008 03:33 PM
Abs` Abs` General Discussion 10 May 5th, 2008 01:55 PM
ABS, DSC and pressure warning lights problem mlt First Generation Faults & Fixes 2 May 2nd, 2007 06:25 PM
