Wifes convertible boot won't open! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 1st, 2010, 08:04 AM
Local Time: 01:59 PM
United-Kingdom Wifes convertible boot won't open!
First post so here goes - My wifes 2004 one convertible boot refuses to open. At the moment I've tied a piece of string to the emergency internal handle so she can pull it to open it - but obviously I'm under pressure to fix it!
I've had the boot apart and put a meter on the switch and it is switching 12V so that works OK. I was hoping this 12V would go straight to the solenoid but the wires go back to the ECU I think. Connector on solenoid shows no voltage across the two wires when I operate the switch so my fear is it is either wiring between the boot and ECU or the ECU itself. I'd appreciate anyones thoughts / experiences.
Old Jan 14th, 2012, 10:09 PM
Local Time: 12:59 PM
England
United-Kingdom mini cooper boot won't open
My boot also wouldn't open and after reading several different theories on several different forums about water in switches, locks, lights and boots unlocking when turning lights on and off etc., I thought I'd better add to the list,what I later found to be my problem.
After pulling all of the above, apart unnecessarily, I found it to be broken wires inside the flexible rubber sheathing where the wires pass from the boot lid to the body. I cut out and soldered new wires in their place and it now works fine.
I'm quite happy if you would like to email me if you need more detail and photo's.djmair@btinternet.com
Dave
Tags: , , , , ,
Boot/Hood open light open all the time aphix First Generation Faults & Fixes 3 Jan 24th, 2011 05:34 PM
Boot Saying Its Open When Its Not? jid Second Generation Faults & Fixes 0 May 12th, 2010 04:21 PM
Best Way to Open Boot Dudley_Dooper Second Generation MINI Exterior 6 Feb 4th, 2010 10:51 AM
Boot won't open!! minidonut First Generation Faults & Fixes 2 May 4th, 2007 01:58 AM
Boot will not open Rab First Generation Faults & Fixes 7 Jan 5th, 2004 10:31 PM
