Driver's door doesn't close properly - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 11th, 2010, 11:37 AM
Bankers's Avatar
Local Time: 01:59 PM
Unhappy Driver's door doesn't close properly
I've had a few problems with this over the past year or so.
I've noticed that when I go to close the driver's door that the window doesn't go down by 5mm and the top of the glass 'clunks' with the roof gutter.
It happens quite often and it's getting worrying because one day I'll go to close the door and smash the glass.
So much so that once the window wouldn't go down when I flicked the electric window switch. It seemed like the whole door electrics are going a bit haywire.
Has anybody experienced this or is it an uncommon thing.
Old Sep 11th, 2010, 12:52 PM
MINICooperMurph's Avatar
aka Nick
Send a message via AIM to MINICooperMurph Send a message via MSN to MINICooperMurph
I had this. They replaced the window motor and all was fine
Old Nov 24th, 2010, 12:41 PM
mate theres a fix on here somewhere which is about hitting the door card in a certain place works a treat and all is fine after its called "re-indexing the window". Its a common thing mine did it and its all working fine now, its to do with people shutting ur door by the glass which isnt as supported as it looks and it upsets the motor so make sure people slways use the handles !!!!!
Old Nov 27th, 2010, 04:10 PM
sidewaze samm's Avatar
Hi
Have you read this thread...
http://www.mini2.com/forum/first-gen...or-opened.html
hope it helps.
Tags: , , ,
Driver's side door won't lock/unlock properly MightyBoognish First Generation Faults & Fixes 5 Nov 26th, 2011 03:05 PM
driver's door doesn't unlock... mini_macky First Generation Faults & Fixes 6 Jul 3rd, 2007 01:35 PM
Sagging driver's door jpeter1093 First Generation Faults & Fixes 1 Jan 6th, 2005 05:04 PM
2004 has one-touch close window on driver's side averyocooper First Generation Interior & Ice 40 Nov 7th, 2003 04:39 PM
Driver's door won't shut! Electric Sheep First Generation Faults & Fixes 6 Dec 18th, 2002 01:13 PM
