Power Steering Fan? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 12th, 2010, 08:22 PM
Local Time: 01:00 PM
Israel
Power Steering Fan?
should the fan of the mini one 2002 work always or just sometimes?
like when just overheated or something?
thanks
Old Sep 14th, 2010, 04:16 PM
MINIAC's Avatar
Canned
Local Time: 06:00 AM
Power Steering Fan Running
Old Sep 14th, 2010, 05:00 PM
sunday-night-rider's Avatar
United Kingdom View sunday-night-rider's Classified Ads
Should be running everytime the normal cooling fan comes on.
“Give a man fish and he will eat for a day...
...teach a man to fish and he will eat for a lifetime”
Old Sep 14th, 2010, 08:46 PM
mab01uk's Avatar
Local Time: 02:00 PM
Do you mean the radiator fan or the power steering pump motor is running? The MINI One & Cooper does not have a small auxilary power steering pump cooling fan in UK, only the Cooper S.
Old Dec 25th, 2010, 11:07 PM
Israel
The power steering fan , in my 2002 mini one .
so there is no way to find out if its working or not?
Old Dec 26th, 2010, 01:51 PM
mab01uk's Avatar
First confirm it has a fan fitted underneath the pump (UK Mini One does not only the MCS). Check fan blades turns ok by hand and it is not seized then apply power to the wiring connections direct from car battery to test.
Old Dec 26th, 2010, 09:46 PM
Israel
ok thanks guys
Old May 20th, 2011, 03:42 PM
Israel
i have replaced my steering pump fan - i don't know when should the fan be working? constantly?
Also, how can i find the fuse responsible for it?
thanks
Last edited by MINIAC; May 20th, 2011 at 04:34 PM. Reason: Posts merged with original thread
Old May 20th, 2011, 04:28 PM
mab01uk's Avatar
Fuses, Relays & Earth Points:
http://www.mini2.com/forum/maintenan...th-points.html
Engine compartment fusebox
F8 30A Heating A/C blower, EHPS cooling fan
No EHPS fan fitted in UK to the Mini One but some export models appear to have it.
(EHPS = Electro-Hydraulic Power Steering)
Old Jul 19th, 2011, 03:35 PM
Israel
checked
Hi
Checked the fuses , all are ok . got under the car and waited till the radiator fan
started working after a drive and the fan of the steering pump did not move.
connected it directly to the battery and it worked fine.
what should i do?
just paid 600 GBP for the steering pump don't want it to die again
Old Jul 19th, 2011, 11:02 PM
mab01uk's Avatar
The fan should run if the AC is on or the radiator fan is running on its higher speed I think.
The PS fan relay might be faulty if the fuse is ok. The PS fan relay is located behind the left kick panel passenger foot-well (RH drive UK). Remove the cover, the fuse panel and turn it over. According to the Bentley manual and my fuse/relay listing above, the relay is K69923.
Old Jul 26th, 2011, 09:42 AM
Local Time: 11:00 PM
Australia
All,
I have this problem as well and been trying to work it out.
Do I have to unbolt the fuse box and remove it to reveal relay K69923?
I removed the plastic kick panel thing to reveal some relays but I dont think they were the right ones. How do I know when I find K69923?
Also how do I check the relay?
thanks
trm
Old Jul 31st, 2011, 08:17 AM
mab01uk's Avatar
Quote: Originally Posted by tttt (original)
All,
thanks
trm
There are more relays on the back of and behind the fuse panel. These are hidden from view and are not very accessible. To access the relays you can usually open the passenger door (UK RHD) and partially remove the rubber door sealing gasket that runs along the door frame - where it changes direction from the door sill to the vertical part of the door frame. Remove a single plastic push fit holder to the upper right of the fuse box access lid. Use some gentle force to push back the plastic kick plate around the fuse box. Standing outside the passenger side of the door looking in as you push the plastic kick plate back you will see the varous relays. The Bentley Mini manual has a photo identifying each relay but is not that clear. If a relay is working you can normally hear it click as the circuit is energised or the component it is controlling is operated.
Tags: ,
Power Steering goes out, high speed fan and power steering fan aren't staying on. Niko First Generation Faults & Fixes 3 Jul 7th, 2008 01:25 PM
Power steering cooling fan oldmots First Generation Faults & Fixes 4 May 31st, 2008 11:38 AM
power steering fan. holdenontoit First Generation Faults & Fixes 5 Jan 17th, 2006 09:45 PM
Power steering fan is gone! thanos30 First Generation Faults & Fixes 4 Mar 21st, 2005 06:07 PM
I don't have a power steering fan! Dom General Discussion 20 Mar 19th, 2005 12:11 PM
