problem with my clutch - easily adjusted? mini one 54!! - MINI Cooper Forum
post #1 of 2 (permalink) Old Nov 5th, 2010, 01:37 PM Thread Starter
Local Time: 05:34 PM
Quoted: 1 Post(s)
United Kingdom Female
United-Kingdom problem with my clutch - easily adjusted? mini one 54!!
hello
I wonder if anyone can help me? The clutch on my mini one (54 plate) is really stiff and doesn't seem to want to release very smoothly - causing an awful gear change! Especially when pulling off first, and going from first to second!
Does anyone know if it is easy to adjust clutch and whether this is a common 'problem' with first generation minis?
Thanks!
jen_mini is offline
post #2 of 2 (permalink) Old Nov 5th, 2010, 01:56 PM
Local Time: 04:34 PM
Hi. Is this mini new to you? I have had my cooper s for 3 weeks and I am struggling with a heavy clutch too. Another member on here advised me to grease the clutch linkages under the bonnet so I am going to give that a go this tomorrow and see if it improves it at all. Will post results. Its seems that a heavy clutch is just how it is with mini gen 1.
Is it when you apply the throttle again that you are getting a jerky change? one of the things that i moticed with the mini is that the fly-by-wire throttle is quite delayed. I found it mainly noticeable in the shift from 1st to 2nd. I am also fitting a sprint booster tomorrow to speed up the accelerator response so hopefully that will smooth out the gearchange too.
I will post the results of fitting the sprint booster and greasing up the linkages. Sprint booster does seem quite expensive at 165 but i my opinion if it helps to resolve the jerky pootling round town journeys it will be money well spent.
See what other owners who have had their minis for longer than me think but it does appear that these are common mini issues with the generation 1.
Will get back to you tomorrow, hopefully with good news....
alzpro is offline
Tags: , , ,
MINI GP clutch / flywheel problem (warranty fix)? PAULWILL First Generation Works 12 Feb 19th, 2011 04:46 PM
clutch problem raees121 General Discussion 9 Sep 25th, 2009 06:20 AM
could this be a clutch problem baha General Discussion 4 Jul 24th, 2005 07:25 PM
Clutch problem!!! janie_cakie First Generation Faults & Fixes 16 Mar 3rd, 2004 04:00 AM
