| Can anyone help me??? Gearbox, Clutch and Flywheel replacement Mini cooper 04 plate!! Please can anyone tell me if you can tell what has made the heat spots on the flywheel... Gearbox problem or clutch problem? I have a faulty gearbox which is being replaced under a Vauxhall warrenty but I am replacing the clutch but the flywheel may need to be replaced. What will happen if I don’t replace the flywheel with the new clutch and gearbox? Im thinking if the gearbox is at fault then maybe the warrently will cover the whole lot??? but need to know if they can dispute the fact that the damage to the flywheel has been done by the clutch and normal wear and tear of the cars age & miles. Can anyone tell me if this could be a correct senerio... Gearbox has fault therefore making the clutch need replacing and in turn has made the flywheel need replacing??? Last edited by Manda82; Nov 11th, 2010 at 01:03 PM. Reason: spelling |
| Tags: clutch, flywheel, gearbox |
| Mini One 04 clutch replacement / gearbox removal | dannyhoffman | Maintenance & MINI Care | 2 | Oct 7th, 2010 08:05 PM |
| Clutch and Gearbox in Cooper 52 plate?? | Tony76! | First Generation Faults & Fixes | 3 | Jul 8th, 2010 03:06 PM |
| Help! Clutch/gearbox/dual mass flywheel problems? | Hayley2009 | First Generation Faults & Fixes | 18 | Dec 7th, 2009 07:18 PM |
| Clutch/Flywheel/Gearbox? (or all 3?) | philip_jones | First Generation Faults & Fixes | 1 | Feb 19th, 2008 08:44 AM |
| Gearbox, Flywheel AND Clutch! | Foxy Mini | First Generation Faults & Fixes | 16 | Aug 20th, 2007 03:20 PM |
