| Hi, this sounds familiar as mine did the same thing a couple of years ago, as well as the windows and sun roof the window wipers had a mind of their own as did the lights and the alarm kept going off. i though it had a poltergiest .anyhow mine went into the garage and they replaced the 'brain' in it, i think this might be refered to as the BCU? sorry no expert, £700 later it was fixed, i wasnt amused i have since read about disconnecting the battery for 10 minutes or so which i hope works for yours, only wish i had tried that with mine first ![]() i have actually had trouble with mine over the last couple of days, it wouldnt start, maybe because of the extreme cold like you were saying, but while trying the window went down on its own and the lights came on even though not switched on, i am hoping its just the battery as jump started it earlier and got it going and it started ok for the rest of the day. hope you have got to bottom of your problem, maybe the BCU has just got damp or wonder if they can freeze and that affects them? Elaine |
| If it is the BC1 these links below should help: The BC1 (Body Control Unit) - Forums The BC1 (Body Control Unit) BC1 faults (it controls alot of things) are often related to water ingress shorting out connectors or causing corrosion inside, from a leaking windscreen, door seal or sunroof if fitted. Reconditioned Exchange BC1 (Body Control Module) are now available from BBA-Reman for a lot less than a new unit from BMW: MiniCooperBodyCtrl |
| Mine did the exact same thing when the driver's door locking unit failed in the 'open' position; this combined with 'comfort opening' feature. Take off the door panel (start on the side that sees most action, usually driver's side) and disconnect the wire from the unit, if the problem stops, there's your culprit. |
| Tags: locked, open, windows |
| Automatic open of the sunroof and windows, but what about automatic closure? | daniel.boizard | First Generation MINI Cooper | 6 | Apr 20th, 2009 04:21 PM |
| Windows and sunroof open and dodgy driver lock | richuk | First Generation Faults & Fixes | 2 | Sep 30th, 2006 06:52 AM |
| Open/Close Sunroof/Windows w/remote key | eekthemeek | General Discussion | 3 | Jul 19th, 2005 12:24 PM |
| remote sunroof/windows open | mattchieux | First Generation MINI Cooper S | 4 | Dec 1st, 2003 07:44 PM |
