| My Gear Box, Clutch both went and my car wont start..errr help! Hi All,
I am new to the this website..I have heard great things and seen some good threads..
This is my first post so sorry if its repeating past disscusions.
I have a 52 plate Mini One. Bought it back in July 2010. Had no probs with it until today. I noticed a strange noise whenever I pressed the clutch down, like a high pitch noise as if something was rubbing slightly. Then it would go away once the car was in gear and the clutch released. Then the clutch itself felt lighter than normal! Car seemed to run ok, when the 1st gear began to stick and then be hard to put in. gears had been fine generally although 1st sometimes felt a bit stiff. I pulled over as I felt something was wrong and turned off the dam thing. When I tried to turn engine back on it would not start at all. Gear is stuck in 1st and wont shift. Clutch when pressed seems to stick!
All in all a bad experience, any ideas?????
I am no mechanic, but reading some posts on here it seems i m a victim of a ******** gearbox!? I left the car parked where it was, got the AA coming to pick it up 2moro morn. I think this is gona be pricey...does anyone have an idea of a possible cost to replace a gearbox and clutch i guess?
Any recommendations on where to take the blasted thing? should i go with a bmw dealer or avoid the high prices? Does anyone know it my mini is still under warranty?
Thanks all Mini's are the best
Alan.... |
