Clonking sound in gearbox - how quickly replace? Hi, I'm in Brussels, have 2001 Cooper that have, from what I gather, a common problem with the gearbox, it makes a knocking/whining sound when accelerate and de-accelerate (OK when you coast). A garage (not Mini) told me I needed to replace the gearbox (was a bit of a shock, was pretty sure it was linked to a problem I knew about in the cylindrical bearings). Now, it's a 2000€ plus story so the garage basically said, if it does not get worse think twice about changing it (it would cost a 25-30% the worth of the car...). Now, does anyone know how this things "break"? Does it just get worse, more difficult to change gears (you have to sync on 2nd, etc.) or does it just completely break down one blue day? I don't drive a lot abut when I do it's usually some distance, hence my question. Thanks in advance, Magnus Brussels Last edited by LappInBrussel; Dec 30th, 2010 at 10:46 PM. |
| If it is the Midland gearbox failing then continuing to drive it normally results in the gearbox being damaged beyond economic repair or being used for 'exchange' reconditioning. I have posted lots of useful information here which may help: Early MINI Rover Midland Gearbox - Forums Mini recon gearboxes |BMW MINI cheap gearboxes Mini Gearboxes Ltd were featured in Modern MINI magazine (July-August 2010) Their prices for an exchange recon gearbox and new clutch fitted to a MINI: 5-Speed Midland gearbox £595 5-Speed Getrag gearbox £690 6-Speed Getrag gearbox £750 Recon box supply only from £325 (Ask for a quote on upgrading from Midland to Getrag as additional parts are required.) Main Dealers quote a minimum of 6 hours for job, 'Mini Gearboxes' fit up to 15 Midland gearboxes a week and have got the job down to around 4 hours by removing the front subframe only from below, instead of the modular front end/rads/bumper assembly. Full method with photos showing stage by stage in MM magazine above (Issue 41). |
| Hi, Thanks for the info. From your link I assume that I have a Midland gearbox (though I'd have to confirm it somehow). Now, I guess the gist of my question is, well was, how do you know when it's getting to that point? Thanks, Magnus |
| Tags: cooper, gearbox |
| Gravel sound coming from gearbox | rghuska | First Generation Faults & Fixes | 3 | Mar 16th, 2010 07:41 AM |
| Loud squeeking sound under full load that went away quickly, after new tires | HarryHBMCC | Wheels, Tyres & Brakes | 2 | Apr 20th, 2006 06:02 PM |
| Clonking from engine bay | russs99 | General Discussion | 3 | May 28th, 2005 06:01 PM |
| Gearbox sound a Micra or what? | Diode Dug | First Generation Faults & Fixes | 4 | Feb 22nd, 2005 08:49 AM |
| Replace gearbox with 5 speed?!? | minimee | First Generation MINI Cooper S | 1 | Apr 18th, 2003 12:10 AM |
