Mini Cooper S JCW power loss - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 28th, 2011, 06:28 PM
Local Time: 01:01 PM
Hi,
I have got 53 MCS JCW but something is wrong with it. I have spent hours digging through mini cooper's forums but cannot find straight answer of what should I do next.
Firstly it takes around 9s to get from 50-70 and the max speed is 127mph which is way too slow for mcs. I have checked the boost and it is just over 1 bar so i presume there is no problem with the supercharger, also there was no faults found when the car was connected to a computer. I don't know in what position the bpv should be but when the car is off I can pull it out slightly further, however when i turn the car on it stiffens and I cannot move it anymore. Do you have any ideas what should I check/changed first?
Many Thanks,
Lucasso
Old Mar 31st, 2011, 06:18 PM
Local Time: 02:01 PM
United Kingdom View DevOnParkLane's Classified Ads
Quote: Originally Posted by lucasso (original)
Hi,
Many Thanks,
Lucasso
Sounds like its restrictive. Try using Super Unleaded Petrol after some injector cleaner (the one you put in with petrol)
Or get a aftermarket manifold. The catalytic converter is VERY restrictive.
Old Mar 31st, 2011, 09:53 PM
Paul@1320's Avatar
MINI2 Sponsor
get a health check / dyno, by someone who knows how to dyno a MINI properly
First M45 Cooper S to run a 12 (12.96@105)
On Nitrous 11.16@123 0-100 7.1991
http://www.1320MINI.co.uk
Tags: , , , ,
Cooper D 2007 - Power Loss uber_cookie Second Generation Faults & Fixes 0 Oct 5th, 2010 07:50 AM
Cooper D Major Loss of Power! Bashman Second Generation Faults & Fixes 1 Apr 1st, 2010 05:20 PM
Loss of power- Mini Cooper S Works!!! PETRAN First Generation Faults & Fixes 7 Jun 12th, 2007 05:27 PM
Loss of Power in my Mini! ianpackham First Generation Faults & Fixes 3 Mar 9th, 2006 02:38 PM
2001 Cooper Power Loss SamHarrison First Generation Faults & Fixes 1 Oct 14th, 2005 02:09 PM
