Advice on a windscreen issue - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 17th, 2011, 03:39 AM
MangaGal's Avatar
Local Time: 12:02 AM
Australia
Hi guys
My 2004 MC was recently repaired after a minor accident. After I got my car back, I noticed my windscreen has this bizarre layer of substance. It becomes distracting and obvious when the sun is in front of me while I was driving.
When the sun hits the windscreen from the front, the windscreen turns into a piece of glass full of fine dots. It almost looks like milky way except that it is uniform.
It took me some time to figure out why this has happened. I think while my car was at the smashrepairer's workshop, they must have forgotten to cover my windscreen when they spray painted my car or a car next to mine or something.
The "milky way" is translucent so I guess it must be paint varnish or some sort.
Apart from scraping the entire windscreen, is there a cleaning agent that could do the trick? Any advice is appreciated.
Old Apr 24th, 2011, 02:46 PM
MINI2 NotSoNewbie
Local Time: 02:02 PM
Ireland Male View dillonmr's Classified Ads
MangaGal, overspray is pretty common and to be honest even in normal conditions glass will pick up surface body contaminants just like bdy work paint. before going to extremes I would recomment using a good glass poish/clearer like car-lack 68 as a first step, this should clear your problem. If this doesnt do the trick, I have used a light degreaser on other peoples cars to clear overspray on paint you obviously have to be carful with degreaser on paint as it can be acidic but you can get non acidic ones, a non acidic wheel clearer will do a similar job and will be fine on glass if you use the car-lack 68 or similar after. hope this helps.
Ronnie
54 plate gearbox issue comments & advice please!!!! mini revs First Generation Faults & Fixes 4 Jun 9th, 2009 04:49 PM
Denison Icelink issue - advice needed! k m s First Generation Interior & Ice 6 Jan 25th, 2009 07:03 PM
Scratches on my windscreen, some advice please!! Mini-Trainer General Discussion 8 Nov 16th, 2007 11:57 PM
Grill for my black cooper & tow bar issue advice please. jazzaj2003 First Generation MINI Exterior 7 Nov 5th, 2007 10:10 AM
windscreen chip...need advice wigman15 Maintenance & MINI Care 10 Mar 7th, 2007 06:46 AM
