| May be some info to help here: Central Locking Problems & Solutions - Forums http://www.mini2.com/forum/first-gen...-pics-inc.html |
| Hi I've got a 2004 model with exactly the same operation. Items 1, 3 & 4 i believe is correct function. BUT item 2, is the same fault as I have got. We've only had the car 4 - 6 weeks & it always unlocked both doors at the same time. It only happened when my wife tried to open the passenger door at the same time as I unlocked the doors via the remote. Is there a way to reset the lock? ![]() If I try the unlock knob on the dash, the door still does not unlock. I have to open the door from the inside all the time. I don't believe its a part fault but I may be wrong ![]() I've searched this site & read several posts on similar problems but the operation mentioned by "Azero" is exactly the same as mine. Any help/reset procedure would be helpful. Thanks. |
| From what I have read its likely to be the lock actuator. Typically this can be intermittent. Currently experiencing this on the drivers door myself (well the missus is), first point of call will be to strip the door down and lube that actuator up, I read the smallest amount of resisance will cause the actuator problems. |
| My 03 S model is doing this. Passenger side does not unlock at all. Always has to be opened for inside. Will have a try at what has been suggested so far (or rather the boyfriend will for me) but any more ideas would be appreciated. Thanks Mini Lover since 2001 Mini Owner since 2011 |
| are you sure its not the key programing? im sure you can choose whether to unlock drivers side only or both. i have the idrive watsit and i think you can change it in there. |
| Tags: actuator, door, lock |
| Door Lock Problem | julsr1 | First Generation Faults & Fixes | 0 | Dec 7th, 2010 03:32 PM |
| Door won't lock at all... | benst86 | First Generation Faults & Fixes | 1 | Sep 29th, 2010 07:13 PM |
| Aluminium door pins... (door lock buttons) | GTT 280 | First Generation Interior & Ice | 3 | Jan 12th, 2003 06:31 AM |
| remote door lock help! | MAXIMINI | First Generation Faults & Fixes | 3 | Sep 2nd, 2002 05:49 PM |
