Power Steering Problems. - MINI Cooper Forum
post #1 of 3 (permalink) Old Jun 8th, 2011, 04:52 PM Thread Starter
Local Time: 07:32 PM
England Power Steering Problems.
Hi,
I have a Mini Cooper on a 53 plate and the power steering is causing me problems. Basically when the engine is relatively cold the power steering is ok when you start the car, but once the engine is hot and you turn the engine off and start it again, the power steering does not work. then if you leave it to cool down for about 30mins. and try again the power steering works again. not once has the power steering failed whilst driving the car, only when the engine is turned off and started again, say when you go for petrol. Do I need a new motor or is it something else?
Garry Pears is offline
post #2 of 3 (permalink) Old Jun 8th, 2011, 10:23 PM
mab01uk's Avatar
Local Time: 06:32 PM
Quoted: 1 Post(s)
Sounds like the pump control electronics are failing when hot, new or reconditioned pump or a clean out inside sometimes works if you are good with DIY mechanics!
More info here:
Power Steering Pump replacement - Forums
mab01uk is offline
post #3 of 3 (permalink) Old Jun 9th, 2011, 07:07 AM
dsakko's Avatar
Local Time: 05:02 AM
Quoted: 1 Post(s)
Australia Male View dsakko's Midnight Black & White 2nd Gen MINI Cooper S Profile View dsakko's Classified Ads
2 possible sources of failure caused by connectors (free fix! ):
- the connectors on the pump itself (1xpower, 1xsignal connector). Access from under the car (not easy).
- obscure but true: Check the connectors on the back of the alternator. A faulty signal can cause the computer to do odd things like thinking the engine is stopped (yes, I've had this happen). Access is from above but I had to take off the manifold (even harder).
Beyond that could be new pump time?? Never met an owner that hasn't had power steering trouble.
R56 MINI Cooper S JCW Challenge
dsakko is offline
Power Steering problems! monkeybusiness First Generation Faults & Fixes 1 Dec 4th, 2009 06:16 PM
Newbie - problems with power steering Brooking First Generation Faults & Fixes 5 Sep 29th, 2008 10:25 AM
HELP HELP!! power steering Problems kee1983 First Generation MINI Cooper S 5 Apr 3rd, 2007 09:14 PM
Power Steering Problems ....help!!!!! CooperS230 First Generation Faults & Fixes 3 Aug 21st, 2006 05:25 AM
Power Steering problems BennyB First Generation Faults & Fixes 11 Jun 24th, 2003 03:05 AM
