Noise from Wheels/Tyres - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 8th, 2011, 10:51 PM
Chezza's Avatar
Local Time: 08:21 PM
Unhappy Noise from Wheels/Tyres
Hi,
Can someone help please, I have a Mini Cooper S and have recently been hearing a loud noise coming from the wheels, it sounds like its a flat tyre, but they're not flat, the pressures are all ok and the tracking has just recently been done, which they said was way out.
They told me that I needed a wheel bearing on Near Side Rear, so that must have been making the loud grinding/knocking noise. I had that done today but it's still doing it, I'm taking it back tomorrow.
Has anyone else had that kind of noise and what could it be? So, it's not tracking, flat tyre and wheel bearing...hope someone can give me some ideas please?
Thanks!
Old Jun 9th, 2011, 12:44 AM
MINIAC's Avatar
Canned
Local Time: 12:21 PM
If the tracking was out, are the tires worn unevenly?
Old Jun 9th, 2011, 07:17 AM
minicore's Avatar
Super Moderator
Local Time: 07:21 PM
United Kingdom Male View minicore's Chili Red & Body Color 2nd Gen MINI John Cooper Works Profile
Is it constant or intermittent? Does it worsen when steering or braking?
How old is the car?
Old Jun 9th, 2011, 08:55 AM
Chezza's Avatar
I suppose it could be the tyres being worn unevenly, but I'm not sure if it would be doing that noise.
It is constant and gettings quicker when I go faster so it surely must be the wheels or tyres. It's got worse/louder in the last couple of days.
The car is an 02. The garage can't seem to find the problem.
Old Jun 9th, 2011, 09:16 AM
minicore's Avatar
Super Moderator
Does the noise appear to come from ALL wheels, or just the front/rear generally? Or one wheel in particular?
Old Jun 9th, 2011, 09:41 AM
Chezza's Avatar
I would it comes mainly from the back, I can't tell what side it is coming from but the wheel bearing was on NSR. And another thing it does, which I forgot to mention, is that when I drive over any bumps or uneven road, the steering pulls me to the side or you could say the steering goes loose for a second.
Also, another thing, I have run flat tyres as well, so wonder if its something to do with them? I've only had my Mini for 3 weeks
Thanks for your help.
Old Jun 9th, 2011, 01:58 PM
What size wheels do you have? Are they 17"? Mine has 17's and when I had run flats the car used to tram line like nothing I've ever seen. I've got rid of the run flats now and it does do it slightly, but not as severe as with the run flats. I believe this to be a trait of the car (mine will pull left or right depending on the direction of the surface or bump)
Old Jun 9th, 2011, 04:43 PM
Chezza's Avatar
Hi yes I have 17" run flats, I was thinking of changing them all to normal tyres. How much did it cost you to change them over?
Did you ever have a strange noise from the wheels/tyres?
Old Jun 9th, 2011, 07:40 PM
Luckily my car had to go back to where I bought it for some work to be done and they put 4 new tires on free of charge. Although normal tires will help tram lining, 17" wheels wont. I've heard smaller wheels eliminate tram lining but in my opinion I'd rather have the 17" for the handling and looks!
I do have a droning noise at the moment but am pretty sure this is a binding brake caliper and nothing to do with the wheels/tires
Old Jun 9th, 2011, 10:11 PM
Chezza's Avatar
Wow that's lucky, I've heard run flats are very expensive to buy, something like £120 each. Yes I know what you mean 17" looks good, but I would like a nicer drive though.
Good point about the possible brake problem, I didn't think of brakes. That's the same noise I have, sounds a bit like a grinding noise.
Old Jun 10th, 2011, 10:40 AM
Yeah runflats are quite expensive, I found the ride to be a lot harder with run flats so much prefer the normal tires. You say you've only just had the car, I like you was concerned at first but I got used to the handling, but dropping down to say 15" wheels would eliminate the tram lining.
I also have a grinding noise, when I press the brake pedal - is this similar to what you have?
Old Jun 10th, 2011, 10:57 AM
Chezza's Avatar
The grinding noise is constant on mine. My dad contacted a garage about wheel bearings and they said to have the brakes checked because brakes binding/seizing is a common fault with mini's.
Have you heard that?
Old Jun 10th, 2011, 11:02 AM
Yeah I have a constant noise too, but louder grinding when I press the brake pedal - sounds like we may have to same problem. I'm presuming mine is binding brakes, haven't checked yet. I have heard its common on MINI's and have eliminated the possibility of wheel bearings because the noise doesn't change when turning a corner.
Old Jun 26th, 2011, 11:48 PM
lukeplayer187's Avatar
United Kingdom Male View lukeplayer187's Classified Ads
you do get a droning noise from the tyres mine do it on standard 16" rims with run flats and its mainly road noise from tyres. iv got to replace the 2 front tyre's on mine and been quoted that run flats are £110 each, they do tram line really bad. iv been told it would have less road noise and less tram lining and more of a comfortable ride from NON run flat tyre's because the side walls are less harder.
Hope thats of any help
Tyres/Wheels Joe Lasbury Wheels, Tyres & Brakes 1 Aug 26th, 2007 10:49 AM
Best wheels and tyres for MC Hubert Rest of the World 8 Nov 16th, 2005 04:23 PM
AK Tyres & NZO wheels Limey Wheels, Tyres & Brakes 1 Sep 2nd, 2003 01:26 PM
Tyres (not wheels) daxler First Generation MINI Tuning 14 May 30th, 2002 08:42 PM
