Gearbox has gone, need new one mini one 90 cv 2002 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 15th, 2011, 08:25 PM
Local Time: 03:03 PM
Spain
Hello all,
I need a gearbox for a mini one 90cv (petrol version). Does anybody has one or know where can I buy a second hand gearbox? Or has anybody another solution.
I am spanish and live in Madrid.
Thank you very much.
With regards.
Old Sep 15th, 2011, 10:27 PM
mab01uk's Avatar
Local Time: 02:03 PM
Lots of Mini 'Midland' gearbox info here which may help you:
Early MINI Rover Midland Gearbox - Forums
'Mini Gearboxes' (link below) ship reconditioned gearboxes from UK to USA so Madrid, Spain should also be possible:
mini gearbox, gear fix - Mini recon gearboxes | BMW MINI cheap gearboxes
Mini and Mini Cooper Transmission. Rebuilt mini transmission
Old Sep 16th, 2011, 06:14 AM
Stortford's Avatar
Local Time: 01:03 PM
Is the clutch slipping aswell?
When the clutch starts slipping it sometimes that the shaft inside has smashed a hole inside the bellhousing. If this has happened youre in for an expensive fix because most reconditioned gearbox people charge a £100 surcharge for this aswell as around £450 for a recon box. These prices dont include fitting and if youre not mechanically minded then dont think about doing it yourself.
I had the same problem with my one only a couple of weeks ago.
The good news was that there was no damage inside my bellhousing and I managed to get the first and second motion bearings changed and some other bits done for £250 which was alot cheaper. I also replaced the clutch with a Valeo which cost me £95.
It took me about 4 hours to get the box out and around 3 hours to get it back in. Would have been alot quicker if I done it on ramps.
If it stays still for too long it gets painted.
Tags: , , , ,
2002 MC and gearbox gone: advice for someone living outside UK (and EU) joriq First Generation Faults & Fixes 3 Nov 24th, 2010 10:30 PM
will a 2003 cooper s gearbox fit a 2002 mini cooper ? samg6620 First Generation Faults & Fixes 5 Aug 6th, 2010 03:50 PM
2002 mini cooper gearbox....HELP!!!! britishracinggreen02 First Generation Faults & Fixes 11 Aug 23rd, 2009 07:03 PM
2002 (02) gearbox wyne ??? erb777 General Discussion 0 Aug 27th, 2007 10:16 PM
MCSW 2002 - Funny gearbox / clutch noise. Is this normal!?? Please help cooperS_matt First Generation Faults & Fixes 2 May 12th, 2007 10:03 AM
