Good Morning everyone!
I am helping a friend fix his 2006 Mini Cooper S John Cooper. Production date is 2006/11
Last spring he had the code P1125 & P1229 and the car went into limp mode. After doing a little research I decided to remove the air box and perform a visual inspection of the TB connector and wiring harness. I then reassembled everything and it seemed to have solved the problem.
A few months later the same problem developed. I removed and cleaned the connections, reassembled, and it seems to be running fine again.
From the information I’ve found so far the throttle body issue was supposed to be solved in 2003 so I don’t suspect that. I’ve also learned the wiring harnesses were assembled using cheap connectors and suspect that might be the problem. I did read that there was an area were the harness would rub against the cylinder head but I’m not clear of that exact location. I have done a good inspection of the harness and don’t see any damage or chafing. When I closely inspected the TB connector I couldn’t see any corrosion or damage. Everything looked to be in great shape.
My questions are
1) What exactly is different on the new and improved wiring harness? To me it would make more sense to just solder and heat shrink a new connector for the TB instead of spending the time and money on replacing the entire harness. Or am I missing something here?
2) Does anyone know where I can find a replacement connector for the TB?
3) Or could the temporary repair be related to me having the battery or computer disconnected while I did the inspection?
Thank you for any information that anyone might be able to shed on this problem.
My questions are
