Cooper won't drive in reverse - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 6th, 2011, 11:11 AM
Local Time: 01:04 PM
Blue Cooper Cooper won't drive in reverse
Hi All,
My cooper (manual, 2005) won't drive in reverse.
I have drove around the block in 1st-3rd gears, although im not 100% those gears were engaged as the gear stick feels unusual.
If when stationary I move gear stick in neutral from side to side it has not spring or definitive feeling!
Any ideas?
Old Nov 6th, 2011, 12:09 PM
United Kingdom View gaz700's Classified Ads
sounds like gear cables/linkages are badly worn or broken
Old Nov 6th, 2011, 12:57 PM
Local Time: 02:04 PM
Hi ya
i agree as long as the gearbox is not making any noise when your driving it
i would go for the linkage or cables.
get some one to move the gear stick and have a look, on your cooper it should be under the battery. it might be easier looking from underneath.
Old Nov 6th, 2011, 04:58 PM
England Male
My wife's 55 reg cooper did this, she drove into a parking space then couldn't reverse out.. turned out it was a new gearbox that was needed. Dealer got a goodwill repalcement from MINI as we were only 6 months outside warranty expiry
Old Nov 6th, 2011, 06:34 PM
Thanks everyone, my initial thoughts are that is is a cable...I'm worried that the dealer (or a bad garage) may say its the gearbox when im sure if I can drive it forward surely it couldn't be a gearbox? Well fingers crossed its a cable :-( thanks again everyone, much appreciated
Old Nov 6th, 2011, 06:37 PM
It doesn't make any sounds when moving by the way, I'm not 100% all the power is in the revs but it defo isn't making a noise,
Tags: , ,
cooper s going into reverse too easy? stevesace First Generation Faults & Fixes 0 Jan 14th, 2008 06:15 PM
Reverse to Drive jolt lynall First Generation CVT & Automatic 5 Oct 7th, 2006 06:18 AM
I Need A Real Answer About The Reverse Grind In The 05 Cooper...please!!!! flav First Generation Faults & Fixes 3 Nov 10th, 2004 03:30 PM
Does Reverse Get Easier on the Cooper S? ianreeves First Generation Faults & Fixes 14 Apr 26th, 2003 08:02 AM
