glove box! HELP - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 14th, 2011, 06:49 PM
Local Time: 01:04 PM
United-Kingdom glove box! HELP
Hi
Need help please! glove box wont shut propery thus leaving light on. so I have to tape the button to keep the kight off. Anyway of disabling the light or any advice please . Mini one convertable.Sorry if i'm in wrong place for the answer
Old Nov 25th, 2011, 07:54 PM
Local Time: 02:04 PM
I'd just pry the glovebox light out with a flat blade screwdriver and remove the festoon - you would have no light in your glovebox but saves the battery drain until the glovebox can be fixed.
Old Nov 25th, 2011, 11:03 PM
England Male
Lightbulb
Hi mate
Does your glove box shut but doesn't stay clipped? I had trouble with mine when I shut it everytime I pulled away it would open and everytime I.went to car in morning it was open thus battery flat. The clip to buy was about 50 quid from BMW so what I did got a spring but not to rigid about 10mm diameter placed behind handle and blue tacked it in. Sound like a bodge I know but you will never see it nor will nobody else because its hidden behind handle and its been fine now for three years and saved me 50 quid.
Hope this helps
Chad
Old Dec 24th, 2011, 09:34 AM
Local Time: 12:04 AM
Australia Male
If you file the latch to a sharper point and at a better angle, also file the receiver vertically a bit to remove the roundness of it.
Lay on the floor facing up to the sky, look behind the chrome button, pull out the two rubber stoppers.
Should stay closed.
Glove box edward2006 Second Generation Interior & Ice 11 Feb 11th, 2007 06:41 PM
Glove Box Lid MCS_LecBlue First Generation Interior & Ice 3 Sep 17th, 2004 03:12 PM
glove box air con? Henry Cooper First Generation Interior & Ice 13 Jul 22nd, 2003 09:04 PM
Glove Box Lumspeed First Generation Interior & Ice 9 Feb 22nd, 2003 10:39 AM
Glove Box neiladkins First Generation Interior & Ice 2 Oct 1st, 2002 04:31 PM
