Windscreen Washer Jets Very Weak Mini Cooper Convertible 2005(55) Hi Guys, New to the Forum, previously was a member of the Rover 75 forum and managed to get a huge amount of help. Anyway, I seem to be having 2 problems with my little Mini Cooper. 1st thing is the washer jets are ejecting fluid to the window but it is very weak and not enough to be cleaning dirt. There is no sound being omitted (should there be a motor whirr?). The second thing is a slight squeeling noise coming from the engine bay at idle and when moving. I'm guessing this will be something to do with a fanbelt? It's not loud just a steady "screach screach screach" with the engine running. Hopefully I can get this sorted without getting a mechanics fingers dirty and just my own. Thanks again guys. gregbuchanan10 |
| Washer motor should be making a noise, more details here: Windscreen Washer Motor Troubleshooting - Forums Slight squeeling noise is probably the auxiliary belt, replace or check alignment if it is annoying (or due for replacement). |
| Hi guys It might be the jet just need cleaning I bought one of these works a treat Mine were full of polish and corrosion |
| Just fixed a very similar sounding problem - if you had no flow then I'd suspect the motor with little flow it may be full of crud - we also have an 05 cabrio! http://www.mini2.com/forum/first-gen...weak-flow.html |
| Washer jets | Billy Smart | First Generation MINI Exterior | 8 | Feb 23rd, 2009 08:35 PM |
| Different Washer Jets? | lilpee69er | First Generation MINI Exterior | 1 | Feb 22nd, 2009 09:26 PM |
| Washer Jets... | djwoody | First Generation Faults & Fixes | 5 | Dec 19th, 2007 10:41 AM |
| Weak Front Washer Jets | MartinSSZ | First Generation Faults & Fixes | 2 | Nov 29th, 2006 10:41 AM |
| Washer Jets | ps_minics | First Generation MINI Exterior | 3 | May 24th, 2006 03:37 PM |
