Noise from front when turning left or right - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 30th, 2011, 07:51 PM
littlemissmel's Avatar
Littlemiss
Local Time: 01:04 PM
United Kingdom Female
United-Kingdom Noise from front when turning left or right
Hi,
When turning into a road or parking, at low speed/ from stationary, there is a whining/rubber on rubber noise. This doesn't happen when driving in a straight line or going round a roundabout etc.
The power steering isnt noisy, so we've ruled that out.
So far we have tried the following:
Gear box rebuild
New clutch & Fly Wheel replaced
New Engine Mounts
Mounting struts replaced
We have also put 4 new wheels on to see if the tyres are slipping on the rims due to corrosion, but that hasnt worked either.
I'd appriciate any suggestions on what we can try next, this noise is driving me nuts & costing me a fortune!!!
many thanks
Old Dec 15th, 2011, 09:18 PM
Local Time: 08:04 AM
I had a similar problem 2 years ago but with the rear right tire. At first I thought it was due to tire wear and not rotating them regularly. Then I replaced the tires but the noise was still there.
It ended up being the bearings that were rusty due to the salt on the roads. The sound was growing louder when turning right because the bearing received more pressure.
Hope this helps. I just subscribed to this forum to answer the thread as I remember it was really frustrating for me too.
Old Dec 17th, 2011, 11:09 AM
England
What year is your mini ? I would put money on the PS pump - They are all noisy on first gens! 2001-2004 I think?
Old Dec 17th, 2011, 12:44 PM
Well
i also facing this problem.
Thanks for sharing.
Old Jan 3rd, 2012, 07:08 PM
Littlemiss
Unhappy Maxb92
Maxb92 Mines 2005 /55 plate. The steering is pretty much the only thing we've not had replaced. To add to my woes, Got in the car this evening after all the heavy rain & my drivers seat is SOAKED!! so now i'm probably gonna have to replace some seals. Its always something....
Old Feb 27th, 2012, 11:00 PM
It's the LSD and the lifetime oil BMW use in the transmission box. The fix will cost you about £30 you need 2 bottles of redline mtl which you can get from dealers on eBay and just follow the link below, remember you need to raise the car and make sure it's level to do the change. I did by jacking the car up and placing wooden blocks under each wheel. After years of putting up with that sound I changed the transmission oil last year and have never heard it since, but have noticed a massive difference in the shifting with this oil it's like a new gearbox, lovely smooth much much better, you can thank me after you have done this enjoy.
I can't post the link as I have not made over 15 posts yet, pm me and I will send you a link to the guide.
Old Feb 27th, 2012, 11:20 PM
Littlemiss
It wont let me pm you, says you don't accept them :-s
Old Feb 28th, 2012, 12:04 AM
Local Time: 02:04 PM
Hi ya
I don't know I you have tried his but I have had this on other cars with the drive shaft gattors making a simalar noise we cleaned them and sprayed a rubber lub on them that stopped it
Anyway Here is a link for gear box oil change castrol do an alternative spec oil you can get this from halfords
http://answers.halfords.com/answers/.../questions.htm
Maintenance :: Girl's Guide to Changing Transmission Fluid - North American Motoring
Old Feb 28th, 2012, 08:27 AM
I had exactly the same problem in terms of symptoms, a rubbing sound groaning sound when turning into a street, it's your LSD making the sound it's not harming your car as its lubed but is annoying. I belive it has somthing to do with the stock oil consistence when heated as the sound is not there when you do a full lock turn from cold.
Anyway it's an easy job should take under an hour once you have all your bits, would stick with redline MTL over anything else as many have recommended it and I can back up the claims, order it on EBay.
Tags: , , ,
Front left wheel noise? Handsy First Generation Faults & Fixes 5 Mar 8th, 2008 12:11 AM
Left front braking noise skay98 First Generation Faults & Fixes 5 Nov 16th, 2007 08:39 AM
HELP!! Squeeking noise possibly from left from wheel when turning at start off sam_pd First Generation Faults & Fixes 7 May 24th, 2007 01:13 AM
Grinding noise - front left Zooloo First Generation Faults & Fixes 4 Apr 9th, 2005 03:09 PM
grinding noise left front tuscan_thunder First Generation Faults & Fixes 4 Aug 21st, 2004 01:04 AM
