| MCS Xenon Fault My car failed it's MOT last month due to the Xenon build flashing on the drivers side. BMW advised me that they would swap the bulb over to make sure it wasn't the starter/ballast. They rang me to inform me it was the bulb. After attempting to drive home today I noticed that the passenger side wasn't working. Not wanting to get a ticket I left the car at work. I've telephoned BMW to report the fault but the invoice states that it was the drivers side and now it's the passenger side. I explained that they swapped them over to check them but I didn't get anywhere. They said that they would have swapped them back which I though was odd. Anyway. I'm now thinking that it is the starter/ballast because it flashes when initially turned on. Would it flash when turned on if the bulb was blown? What would the easiest thing to swap over to check. The bulb or the ballast? |
| REAR WINDOW SHATTERING FAULT - dealers aware of fault | Mini Virgin | First Generation MINI Convertible | 161 | Feb 14th, 2012 12:02 PM |
| compression fault along with traction control fault | lebeouf | First Generation Faults & Fixes | 2 | Jun 30th, 2010 12:44 PM |
| Upgrading from regular xenon to facelift xenon headlights? | AlanJCW | First Generation MINI Exterior | 1 | Apr 14th, 2010 12:19 AM |
| Xenon Headlight Fault, Always on pointing at the ground | rhenium188 | First Generation Faults & Fixes | 0 | May 6th, 2009 01:59 AM |
| Fault After Fault - At Wits End! | COOPERUK | First Generation Faults & Fixes | 6 | Oct 13th, 2003 12:03 PM |
