R53 won't start - battery appears fine, absolutely nothing when key turned - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old Dec 19th, 2011, 08:29 PM
Local Time: 01:05 PM
just ask your local car thief! but basically, taking the live to starter from the back of the key barrel. I got so fed up with the problem I started from the key and worked back and solved it in minutes. I had had BM guys with multi-meters and at one stage, an osciliscope, all over the car. It was such a sucker fault that everyone that had a go at fixing it admitted that it had them baffled and they would never have considered changing the faulty part. I guess what I'm trying to say is to systematically look at everything afresh and treat everything as suspect no matter how simple until proven. But good luck anyway as I know how annoying a problem like this can be.
  #17 (permalink)
Old Dec 20th, 2011, 08:13 PM
Hi, thats the very part. It looked slightly different but the white plastic centre was just deforming. If you can get to yours just put a screw driver in the white centre and turn it and see if your car starts. If it looks ragged then it could be the cause as the part that turns it is metal and can slowly wear down the white nylon. I'm not known for my engineering prowess but this is fault is identical to mine. Good luck.
  #18 (permalink)
Old Dec 24th, 2011, 09:12 AM
Local Time: 12:05 AM
Australia Male
We have the same intermittent problem with or R53.
But it's only started happening with our new transponder key.
Also the locksmith couldn't get the central locking to work.
I'm suspecting the immobilizer. There's talk of the transponders losing their programming.
I'm considering having an aftermarket alarm system installed and bypassing the factory immobilizer completely. Way cheaper than going to the dealer.
If you have a manual key use that for a while.
If it starts every time, you'll know it's the remote key causing the trouble.
Good luck with it.
  #19 (permalink)
Old Jan 9th, 2012, 01:25 PM
Did you get it fixed in the end?
  #20 (permalink)
Old Jan 16th, 2012, 09:48 PM
Sorry for the delayed reply people - blame mini! haha.
I have indeed fixed this!! It was the ignition switch, as suggested! Although not exactly the same as yours - the centre did turn, just it would't send 12v to the starter. I'm not sure why and I haven't taken the switch apart.
So glad it's fixed, and at a good price too! Many thanks for everyone's help
power steering pump stays on when engine is turned off and flattens battery mini46 First Generation Faults & Fixes 3 Feb 17th, 2010 07:07 PM
Power steering pump running after the MINI is turned off and flattening the battery? Redwytch First Generation Faults & Fixes 1 Jul 24th, 2008 09:00 PM
Engine won't start - Battery Problem? jleydon First Generation Faults & Fixes 3 Jul 11th, 2006 04:12 PM
Battery no start roadmaster First Generation Faults & Fixes 1 Jan 8th, 2006 07:57 AM
