DIY R50 Cooper Fuel filter/sender problems - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 14th, 2011, 05:29 PM
Local Time: 06:05 PM
Pakistan
Hi all, im hoping you can help me with a problem i have.
Yesterday i serviced my R50 cooper 2001, when it came to the fuel filter i looked in the manual to find it is in the tank etc.
When i pulled the sender unit out i found it looks different to the one in the manual, and every one ive seen on the how to's online, most seem to simply have a screw top and a paper filter, which is what i was supplied with, however my sender has clips that you need a million hands to hold and pull the top off! and a metal filter which i cant seem to remove once the top is off!
After swearing at it for a while i gave up and popped it all back together, now my guage is reading empty when the tank is full!, i checked everything and even moved the floats manually, the guage moves all the way down to the stop, but only goes up to just above empty!
What i want to know is why is my sender different to everything else ive seen, and what have i done wrong?
Any help would be much appreciated!
Many thanks
Gareth
R50 Cooper Fuel filter/sender problems Dolts First Generation Faults & Fixes 0 Dec 11th, 2011 09:55 AM
'07 Mini Cooper S Fuel System Problems BJSuperCooper Second Generation MINI Cooper S 1 Oct 25th, 2011 05:01 PM
Cooper D Fuel Filter Change ... chopper_harris Maintenance & MINI Care 1 Nov 15th, 2010 09:56 AM
Fuel filter on Cooper S m3mpower Maintenance & MINI Care 4 Mar 29th, 2010 07:01 PM
fuel filter R50 Nick Maintenance & MINI Care 9 Dec 28th, 2007 01:15 AM
