Mini One Diesel 2004 - Cooling system help - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 15th, 2011, 12:08 PM
Local Time: 02:05 PM
Hi everyone
I have a 2004 mini one diesel, around 108,000 on the clock and am experiencing problems for the first time.
These include:
- heaters blowing cold air
- bubbling in coolant bottle (froths over when you open it)
- engine fan comes on almost straight away
-Squeaking noise from engine
- overheat once last week
From reading this forum, it could either be the head gasket, thermostat or radiator causing the issue.
Obviously would like to test the cheapest thing first - thermostat, but how do you get it out to test? My brother is a VW mechanic and is looking at it, but obviously not being a mini specialist, this is proving to be a bit of a challenge. Do you have to take the whole front-end off? At this rate it would take him hours just to do that.
any help appreciated!
Tags: ,
Mini One Diesel 2004 Engine Problem buzzboardtony First Generation MINI One D 4 Apr 15th, 2010 09:44 PM
cooling system..is this normal stevetigersix First Generation Faults & Fixes 7 Aug 6th, 2009 08:35 AM
Problem With the cooling system Woolly44 First Generation Faults & Fixes 5 May 31st, 2008 05:54 AM
Intercooler Cooling System scm6079 First Generation MINI Cooper S 1 Aug 27th, 2002 05:36 PM
