ABS,ASC,Tyre pressure light fault codes. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 15th, 2011, 02:26 PM
Local Time: 01:05 PM
Hi all just wondering if anyone could shed some light on this for me.
Have been to get the fault codes read by my local garage after all 3 lights (ABS,ASC,Tyre) decided to start been on continuosly, before it was intermittent only came on when it was wet and went off on a nice day all throughout summer they have been fine but right now they wont go off.
My garage used a snap on reader and these were the the codes
SDA1 Speed sensor front right
SDB0 Spped sensor rear left
SE18 can data error from DME/DDC
SDFE System voltage 9 Volts
I understand the first 2 but wonderd are the 2nd two related to just a bad sensor. Garage said these were manufactures codes.
I have replaced the 2 faulty sensors but the lights are still on, will they go out or will i have to take it back to have the codes removed.
Thanks for any help.
Old Dec 15th, 2011, 02:42 PM
Local Time: 02:05 PM
United Kingdom Male View Liam mini 35's Classified Ads
All those lights came on my car the other month, it was the abs sensor that needed changing. Cant tell how much it was as the car is under warrenty atm.
Old Jan 26th, 2012, 09:29 AM
Rattle, Rattle, Rattle...
United Kingdom View buckmeister's Indi Blue & White 1st Gen MINI Cooper Profile
I had a similar issue to this before Christmasm but the speedo stopped working as well.
It turned out to be damage to the wiring loom that goes to the ABS/ASC unit in the engine bay. The cable had slipped under the pump support bracket and chaifed through 1 of the wires enough to short it against the bracket and blow a fuse. I managed to thread the cable and plug under the pump and splice in a piece of wire to replace that section. Soldering and shrink wrapping it was a pain.
Because of where the wire sits and that its covered in a fabric wrap that can absorb water it could be the same issue, just different wires?
Emission Light/ o2 sensors/Fault codes & Mots roland2003 First Generation Faults & Fixes 48 May 16th, 2010 05:07 PM
Tyre Pressure Light daveyc2k8 First Generation Faults & Fixes 2 Apr 2nd, 2008 10:25 AM
tyre pressure light westycoopers First Generation Faults & Fixes 3 Dec 10th, 2007 08:24 PM
Tyre Pressure light BritishRacingGreen General Discussion 16 Dec 3rd, 2004 02:13 PM
Has anyone had the dsc tire pressure light fault sucessfully repaired? KAMAKAZI First Generation Faults & Fixes 0 Mar 29th, 2003 10:37 AM
