Halo sidelights draning battery daily! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 18th, 2011, 12:21 PM
Phenom's Avatar
Vercetti Clan
Local Time: 01:05 PM
United Kingdom View Phenom's Classified Ads
Unhappy Halo sidelights draning battery daily!
Hi all,
My mini has halo or angel-eye sidelights fitted, they look great but they are causing me alot of problems this winter!
I know alot of people say that the residual glow is just because they use so little power but in addition to that, mine periodically flash a full glow even when the ignition is off, locked and alarmed! This is causing my battery to go dead almost daily.
I tried to find the fuse for the sidelights so at the very least I can pull this out when the car is not in use, this fuse is NOT fuse F10 or F010 in the engine compartment (perhaps it is different in an MCS?), does anybody know the correct fuse?
Or any other ideas for stopping these excitable lights from having a party while the car is trying to sleep?!
THANK YOU!
Old Dec 18th, 2011, 02:05 PM
mab01uk's Avatar
Local Time: 02:05 PM
I have Halo sidelights fitted but never had any problems.
Maybe try asking Mike at NewMiniStuff who sells Halo's and is a helpful expert on Mini lighting problems.
He is also a sponsor on the TotalMini forum here (MikeytheMini):
New MINI Stuff - totalMINI Forums
Old Dec 18th, 2011, 07:32 PM
Phenom's Avatar
Vercetti Clan
Wish I had bought mine from him, can't remember where I did buy them from now.
Thanks I will ask!
If anybody else has an idea about that fuse it would be greatly appreciated.
Old Dec 18th, 2011, 08:01 PM
3Bars
View 3bars's Classified Ads
You can solder a 1K resistor to LED lighting systems to stop this problem.
Quote:-
"There is sometimes a small amount of current running through the MINI electrical system that is not enough to light a regular bulb, but enough for an LED. You can Install a 1K ohm resistor in parallel with the LEDs (between the positive/negative wires). This provides an extra electrical path that, during low level power, prevents the LED from getting enough power to light up."
LED Halo Sidelights ian16ac First Generation MINI Exterior 4 Jul 21st, 2011 04:13 PM
does anyone have the halo LED sidelights? rich345 First Generation MINI Exterior 3 Aug 5th, 2010 03:11 PM
Halo sidelights & halo headlights rubberj00 Second Generation MINI Exterior 13 May 30th, 2009 03:51 PM
My new Halo Sidelights Darthbladerni First Generation MINI Exterior 18 Mar 21st, 2008 01:09 AM
