| Difficulty/resistance shifting to the 5th and Reverse Another issue.... our Mini Cooper with 5 speed (2002) so presumably the Midland gearbox has developed some resistance when shifting to the 5th and Reverse as if there is a rubberised cushion preventing smooth movement of the gear lever into the right hand side slots. Do you guys know what the problem is? I'm starting to miss the CRX I had for 14years..... |
| You can check one end which is connected to the top of the gearbox under the air cleaner. The other end you'd need to go under the car and open up the underside of where the gearstick is. Not sure what could be causing it, so I can't guide you on what you're looking for. ![]() R56 MINI Cooper S JCW Challenge |
| Thanks for your reply. I took it to a garage and the mechanic seems to think it is the cable also. He said he "freed it up" but he did not feel that the shift feels 100% although better. If one was to change cable(s), is there a DIY guide on this and if so is it easy enough? |
| http://www.bmw-planet.com/lib/mini/GEAR%20SHIFT.pdf A lucky find I've lost my Bentley R53 manual somewhere so don't have access to anything else. ![]() R56 MINI Cooper S JCW Challenge |
| Battery cable squib resistance | Coopspeed | First Generation Faults & Fixes | 1 | Sep 11th, 2011 01:42 PM |
| Difficulty with reverse gear | lutty | First Generation Faults & Fixes | 7 | Oct 21st, 2009 09:34 PM |
| Reverse gear difficulty? | richl | First Generation Faults & Fixes | 33 | Apr 26th, 2003 03:49 AM |
| rollin resistance | gillsg | First Generation MINI Cooper S | 3 | Apr 17th, 2003 11:47 PM |
