| o4 mini cooper hesitating please help.. Can anyone help me with this i would highly appreciate it. I am having an issue with my mini cooper what is happening is when i press the gas pedal it jerks and feels like it is hesitaing also it does it when i am at a normal speed as well.but the thing is it only does in maybe 3 or 4 times and then stops.it used to only do it once in a while n now it seems like it does it quite more often does anyone know what this issue could be if anyone does please let me know thank you. |
| well it does it when i go like 5-10 miles per hour and it does it as well when i do like 40-50.too i have an appt at a bmw dealership for them to look at but i just dont no if it could be somthing simple.thats why i wrote on here to see if anyone can help me |
| If it is related to the automatic cvt transmission control module sometimes a reset of the 'computer brain' helps......do this by disconnecting the battery for half an hour. Also check the battery is giving full power under load, an original 04 battery could be starting to fail even though it can still start the engine. |
| Wonder if the OP could be referring to the "yo-yo" effect caused by a weak spring in the bypass valve ? $125 Detroit Tuned BPV could be the fix. 2004 MCS JCW, 15% pulley, Dinan CAI, MSD ignition & wires, Mynes V2 header, TSW rear control arms, H-sport front and rear sway bars, H-sport lowering springs, Powerflex bushings all around, modified Forge intercooler, M7 STB , ATI Damper |
| 2009 Cooper S engine problems (misfires and hesitating) | JCWcooper | Second Generation Faults & Fixes | 13 | May 6th, 2012 09:34 PM |
| Mini ONE 2002 Hesitating/Jerking | omri617 | First Generation Faults & Fixes | 2 | Dec 14th, 2011 10:01 PM |
| The new 2011 Mini Cooper, Cooper S Cabrio are Here !! Spy picsand Cooper S Clubman | Cal330ci | General Discussion | 6 | Sep 12th, 2010 11:55 PM |
| Mini One se7en , Cooper Parklane ,Cooper S Checkmate Oficial MINI VIdeo | jordan | General Discussion | 0 | Jul 20th, 2005 06:09 PM |
| MINI Cooper vs. MINI Cooper S, (Pretty Long Message) | Nathant | General Discussion | 32 | Aug 11th, 2003 06:12 PM |
