Central Locking Problems - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 3rd, 2012, 02:09 PM
Local Time: 01:06 PM
Northern Ireland
Hello,
I have a Mini Cooper 2002 which has developed a strange issue with the central locking.
When I lock the car with the key fob the locks all go down then come back up again (however the alarm arms itself). This also happens when I use the toggle switch inside the car. all locks go down then come back up immediately.
Last night I managed to get the car manually locked only to come out to an unlocked car this morning!
Has anyone any ideas?
Old Jan 3rd, 2012, 05:37 PM
mab01uk's Avatar
Local Time: 02:06 PM
Couple of links below with info which may help:
Central Locking Problems & Solutions - Forums
The BC1 (Body Control Unit) - Forums
Old Jan 3rd, 2012, 08:25 PM
Local Time: 12:06 AM
Australia Male
Quote: Originally Posted by disilldo (original)
Hello,
Maybe the button is stuck on contact inside the remote.
Use a manual key without remote locking if you have one.
Leave the remote key well away from the car.
I suspect many of these immobilisers become faulty as they near ten years.
We can't program our new key to unlock and sometimes the car won't start.
When we use our manual key, it's fine.
I've been quoted to rip out the factory immobilser and install a quality remote alarm system for the same price as a replacement key from a dealer.
You can still use the existing lock motors.
Old Jan 3rd, 2012, 08:31 PM
Northern Ireland
Cheers guys.
I fear that it might be that the BCU is just cabbaged! Ill try taking it out and seeing if there are any signs of corrosion and will also check the door latches.
For the time being I have taken out the fuse for the central locking meaning I can manually lock the car with the key without an alarm. Not ideal but at least it locks!
Tags: , ,
Central Locking JamesBevan First Generation Faults & Fixes 3 Mar 15th, 2011 04:41 PM
Central Locking plus internal switch for locking door blows fuse iow-cookie First Generation Faults & Fixes 0 Jun 15th, 2010 02:40 PM
Remote Central Locking Problems bazzer79 First Generation Faults & Fixes 3 Dec 19th, 2008 08:38 PM
Central Locking nonofagan2 First Generation Faults & Fixes 2 Jul 8th, 2008 08:14 PM
Central locking but no Central Openning?? oceanstarBug First Generation Faults & Fixes 3 Mar 19th, 2005 05:02 AM
