Xenon Fault - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 15th, 2012, 08:05 PM
MINI2 NotSoNewbie
Local Time: 02:07 PM
Ireland Male View dillonmr's Classified Ads
Xenon Fault
Hi, I'm having a fault with the Passenger Xenon Headlight on my 05 R53 MCS. Both lights were working fine up unitl about a week ago. then the passenger headlight started to act up. At first it didnt come on on start up, would give give a flicker like a florence tube light, but would go out, then as driving sometimes it would come on but wasnt as bright as the driver side. Then it started to work for a cpl days from start up but again not as bright as the drivers (slightly dimmer). Now it's not coming on atall, giving the odd flicker at start up but thats it. Any ideas what i need to do to get this fixed, havent much experience with Xenon's, thanks.
Ronnie
Old Jan 16th, 2012, 09:06 AM
RobbieA's Avatar
England
United-Kingdom
I am no expert but suspect you may need a new Xenon bulb. This is a dealer fit and the bulb is not cheap, plus labour.
I would suggest popping into your garage and let them check it out.
Tags: , , , , , ,
REAR WINDOW SHATTERING FAULT - dealers aware of fault Mini Virgin First Generation MINI Convertible 161 Feb 14th, 2012 12:02 PM
MCS Xenon Fault A18XVM First Generation Faults & Fixes 0 Dec 7th, 2011 05:12 PM
compression fault along with traction control fault lebeouf First Generation Faults & Fixes 2 Jun 30th, 2010 12:44 PM
Upgrading from regular xenon to facelift xenon headlights? AlanJCW First Generation MINI Exterior 1 Apr 14th, 2010 12:19 AM
Xenon Headlight Fault, Always on pointing at the ground rhenium188 First Generation Faults & Fixes 0 May 6th, 2009 01:59 AM
