Mini Cooper 2002 - Power Steering Whine - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 16th, 2012, 04:35 PM
Local Time: 02:07 PM
Hi again,
We have a 2002 Mini Cooper, done approx 75,000 miles.
The car makes a sort of whine noise when steering, only really noticeable when performing manouvers, parking etc.
Any one know of a reason for this or if its normal?
Many Thanks,
Luke
Old Jan 16th, 2012, 04:46 PM
Quote: Originally Posted by lucass_247 (original)
Hi again,
Many Thanks,
Luke
This is normal, you should be worried if it doesn't make a whining noise
Old Jan 16th, 2012, 07:36 PM
mab01uk's Avatar
A characteristic of the earlier Mini's..........you will grow to like it!
Old Jan 17th, 2012, 12:01 PM
Acallahan's Avatar
MINI fanatic
Local Time: 09:07 AM
United States Male View Acallahan's Classified Ads
Could also mean power steering pump is on its way out.
2004 MCS JCW, 15% pulley, Dinan CAI, MSD ignition & wires, Mynes V2 header, TSW rear control arms, H-sport front and rear sway bars, H-sport lowering springs, Powerflex bushings all around, modified Forge intercooler, M7 STB , ATI Damper
Old Jan 17th, 2012, 12:05 PM
mab01uk's Avatar
Not necessarily......many are just noisy even when a replacement is fitted. Mine has been noisy for the full 5 years I have owned it!
Old Jan 21st, 2012, 06:38 AM
BRGJCW's Avatar
Online
Local Time: 11:07 PM
Australia Male View BRGJCW's British Racing Green & White 1st Gen MINI Cooper S Profile
yep whine here too - some think it's the supercharger!! No issues with the steering...
Old Jan 21st, 2012, 07:10 AM
United Kingdom Female
You only need to worry if the noise changes, the power steering on the earliest MINIs was very noisy.
Old Jan 22nd, 2012, 06:53 PM
England
I actually missed the whine after I had my power steering pump changed.
Old Jan 26th, 2012, 12:27 PM
littlemissmel's Avatar
Littlemiss
Local Time: 01:07 PM
MCSC 55 plate 33'000
Its definitely not a "normal" noise, it didnt always do it.
Mine is the same, still trying to figure out what it is. I've had a new clutch & fly wheel, rebuilt the gearbox, suspension rebuilt, all seals replaced, tyres all changed & checked for rubbing, cv joints replaced etc. The steering is now the last thing theyre lookin at. The noise occurs when turning round corners, parking etc. Not when at standstill. It sounds like a rubber on rubber friction noise.
Tags: , , , , ,
Mini Cooper 2002 Power Steering pump Change MiniCooperCardiff First Generation Faults & Fixes 7 Jan 29th, 2011 11:12 AM
Will a power steering fan gaurd fit on a 2002 mini cooper s fozworth First Generation MINI Tuning 4 Oct 2nd, 2006 07:45 PM
Power Steering Whine even when car is OFF wow First Generation Faults & Fixes 5 Mar 2nd, 2006 12:33 PM
Power steering whine? UberFisch First Generation MINI Cooper S 7 Jan 31st, 2006 09:31 PM
Power steering whine arabinow First Generation Faults & Fixes 7 Aug 7th, 2002 07:26 PM
