Intermittent Window Washer Problem - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 17th, 2012, 09:33 PM
Local Time: 01:08 PM
Northern Ireland
Angry Intermittent Window Washer Problem
Hi Folks,
Having a small issue with my Window Washers which I was hoping someone could help me with.
Washers on the front sometimes don't work on the drivers side and then sometimes switch to only work on the passenger side and not the drivers! (very annoying)
Anyway I have taken a look at the tubes leading to the washers and found a valve that splits the flow between the two washers (with a wee red cap). It seems that this valve had popped open, I pushed it back down and both work again. Only problem is this only lasted about 2 days.
Does anyone know what this wee valve does? Or if it can be replaced or what? I have seen an old T shaped thing on ebay that could probably do the job but does anyone know how to fix or if there is a replacement part?
Old Jan 18th, 2012, 10:38 AM
Local Time: 02:08 PM
Item 5 costs £1.70 at full retail price from the dealers so that's probably the easiest way to get it. The description of the part says "return valve" so it may be more than just a tee piece.
If the "popping open" is one of the tubes coming off the end of item 5, you might need some new tubing too, and retail is £8.21 per metre which seems incredibly expensive.
Old Jan 27th, 2012, 12:35 PM
Northern Ireland
Thanks for the response on this and the Diagram! I am going to look to get a new return valve for this car then as it is the top of the valve that pops not the pipes.
Old Jan 30th, 2012, 07:51 PM
Northern Ireland
Hi Angib, Can you tell me where I can buy a return valve like the one in your diagram above on the internet?
I am having trouble finding it!
Old Jan 30th, 2012, 09:45 PM
mab01uk's Avatar
Have you tried:
www.bmminiparts.com - Home
or
BMW MINI Spares - Home
or
Mini Spares UK - Mini Spares UK
or
MiniMatt|BMW|MINI|Modifications|Parts|Spares|Servi ce|Tuning|Repairs|Racing
rear window washer charmingman First Generation Faults & Fixes 4 Mar 24th, 2011 11:48 AM
Intermittent Starting Problem jbenekeorr First Generation MINI Cooper S 1 Dec 23rd, 2010 07:17 PM
Window washer not working ! snootsu First Generation Faults & Fixes 10 Apr 11th, 2007 07:27 AM
Intermittent Audio problem HoosierMini First Generation Faults & Fixes 3 Jul 2nd, 2003 01:12 AM
intermittent power steering problem dej First Generation Faults & Fixes 29 Apr 1st, 2003 12:25 AM
