| Mini Cooper Headlamp motor problem Hi I recently changed the driver's side dipped beam bulb on my 2004 Mini Cooper about the same time the manual adjustment control on the passenger head light failed and it now points to the ground (I guess at it's lowest setting). It seemed to close to believe that these things are not related. I understand that the motor signals go the driver's side then the passenger side in series (?). I've checked the wiring and both connectors and everything seems fine. I wondering if I could have upset something when changing the bulb. Thanks for any advice Alan |
| Tags: headlamp, motor cooper |
| starter motor problem | talkalot | First Generation Faults & Fixes | 0 | Jul 19th, 2011 10:28 PM |
| headlamp life problem | morgsmini | First Generation Faults & Fixes | 4 | May 7th, 2008 05:54 PM |
| Headlight Motor Problem | mini5lover | First Generation Faults & Fixes | 7 | Mar 5th, 2008 03:56 PM |
| Motor Problem!!! | quim | First Generation Faults & Fixes | 6 | Aug 21st, 2004 07:16 PM |
| Headlamp problem - anyone had this before? | Tonyt3 | First Generation Faults & Fixes | 12 | Dec 28th, 2003 04:29 PM |
